g920i repair drk REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. Operation: Repair DRK Selected model: SM-G920I Software version: 25.2 Checking Recovery file... OK Searching USB Flash Interface... detected COM4 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 5.1.1 Boot version: G920IDVU3DOJ6 Platform: exynos5 Boot serial: 06157df6bab8b830 Product board: universal7420 Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... OK Repairing DMVT key... error Rebooting phone... OK Repair DRK done Done with Samsung Tool PRO v.25.2 Now the touch does not add up I have done flash and root and nothing touch only hits wrong after repair rdk |
try install new recovery pack or delete old recovery from software folder and repeat repair drk |
this was in another post: To fix digitizer just do this: FIX: Dial *#2663# in the dialer and update the touch screen panel firmware by selecting 'TSP FW update (General)' button. |
this code does not work in my already rolled several firmware and still hitting the wrong touch |
support Z3X any solution or not help please |
i have the same problem with touch with G920F |
i have same problem plz help i try downrade try root try 6.01 touch at left side not working problem after repair drk pls helppppp |
With which firmware you did succ. downgrade 601 to 511? |
5.1.1 6.0x of several machines it's nothing |
g920idvu3doj6_g920iolc3doj6_xsp_android_5.1.1.oct |
the problem was after the repair drk already ran several firmware and not solve wait Z3X sends a solution |
touch problem not stop but like you use touch by meirror if you press left will touch right so any one know how repair touch now i try update downgrade hard resset change efs i make new problem with drk and repair it agian with octupos same promblem touch you press it like mirror |
if any one have pit file for g920i send to me to try erase hole flash |
