Old 04-23-2016, 17:19   #1 (permalink)
bruno santana's Avatar
Member: 2235684
Thanks Meter: 189
g920i repair drk
REPAIR INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings.
Operation: Repair DRK
Selected model: SM-G920I
Software version: 25.2
Checking Recovery file... OK
Searching USB Flash Interface... detected COM4
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Waiting ADB device... OK
Reading phone info...
Android version: 5.1.1
Boot version: G920IDVU3DOJ6
Platform: exynos5
Boot serial: 06157df6bab8b830
Product board: universal7420
Initializating zTool... OK
Running zTool, please wait...
Start... OK
Init... OK
Generate and check client proof... OK
Verify proof by client... OK
Checking DRK status... OK
Repairing DMVT key... error
Rebooting phone... OK
Repair DRK done
Done with Samsung Tool PRO v.25.2
Now the touch does not add up
I have done flash and root and nothing
touch only hits wrong after repair rdk
The Following 2 Users Say Thank You to bruno santana For This Useful Post:
Old 04-23-2016, 21:31   #2 (permalink)
mk
mk's Avatar
Member: 199768
Sonork: 100.1607571
Thanks Meter: 16,118
try install new recovery pack or delete old recovery from software folder and repeat repair drk
The Following User Says Thank You to mk For This Useful Post:
Old 04-23-2016, 22:37   #3 (permalink)
krisu0007's Avatar
Member: 1670851
Thanks Meter: 245
this was in another post:
To fix digitizer just do this:
FIX:
Dial *#2663# in the dialer and update the touch screen panel firmware by selecting 'TSP FW update (General)' button.
The Following 2 Users Say Thank You to krisu0007 For This Useful Post:
Old 04-24-2016, 12:34   #4 (permalink)
Member: 2235684
Thanks Meter: 189
this code does not work in my
already rolled several firmware and still hitting the wrong touch
Old 04-25-2016, 12:19   #5 (permalink)
Member: 2235684
Thanks Meter: 189
support Z3X
any solution or not
help please
Old 04-25-2016, 12:20   #6 (permalink)
Member: 2235684
Thanks Meter: 189
support Z3X
any solution or not
help please
Old 04-25-2016, 16:01   #7 (permalink)
Member: 25110
Thanks Meter: 60
i have the same problem with touch with G920F
Old 04-25-2016, 16:23   #8 (permalink)
Member: 220123
Thanks Meter: 19
i have same problem plz help
i try downrade try root try 6.01 touch at left side not working problem after repair drk
pls helppppp
Old 04-25-2016, 16:29   #9 (permalink)
Member: 25110
Thanks Meter: 60
With which firmware you did succ. downgrade 601 to 511?
Old 04-25-2016, 16:35   #10 (permalink)
Member: 2235684
Thanks Meter: 189
5.1.1
6.0x
of several machines
it's nothing
Old 04-25-2016, 17:14   #11 (permalink)
Member: 220123
Thanks Meter: 19
g920idvu3doj6_g920iolc3doj6_xsp_android_5.1.1.oct
Old 04-25-2016, 17:17   #12 (permalink)
Member: 2235684
Thanks Meter: 189
the problem was after the repair drk
already ran several firmware and not solve
wait Z3X sends a solution
Old 04-25-2016, 20:10   #13 (permalink)
Member: 220123
Thanks Meter: 19
touch problem not stop but like you use touch by meirror if you press left will touch right
so any one know how repair touch now
i try update
downgrade
hard resset change efs
i make new problem with drk
and repair it agian with octupos same promblem
touch you press it like mirror
Old 04-25-2016, 20:12   #14 (permalink)
Member: 220123
Thanks Meter: 19
if any one have pit file for g920i send to me to try erase hole flash
Old 04-25-2016, 20:32   #15 (permalink)
Member: 2235684
Thanks Meter: 189
Support files | z3x-team
Page generated in 0.21901 seconds with 7 queries
