Old 07-15-2016, 23:39   #1 (permalink)
tito millo's Avatar
Member: 390642
Sonork: 100.1573430
Thanks Meter: 2,474
G920T 6.0.1 FRP Locked and DRK Damaged
Hello, i got a G920T with 6.0.1 problem with phone its that after update it got DRK damaged, and to repair it is needed to disable FRP, i was trying to download boot by flashing sboot.bin form older version with out success. Phone installed version is G920TUVU4EPF1
Please if someone can help me to recover this phone, appreciate the help.
Operation: Reset FRP/React/EE
Selected model: SM-G920T
Software version: 25.9
Searching Samsung USB Flash Interface... detected COM27
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... error
Done with Samsung Tool PRO v.25.9
Br,
Tito Millo
Old 07-17-2016, 07:47   #2 (permalink)
jjmpda's Avatar
Member: 2381538
Thanks Meter: 65
you need eng combinatoon firmware to fix your problem
Old 07-17-2016, 10:48   #3 (permalink)
Member: 2517404
Thanks Meter: 8
No Downgrade possible for this phone with PF1 ..
Old 07-17-2016, 10:56   #4 (permalink)
Member: 1118550
Thanks Meter: 31
[j7] sm-j700f xxu2apc4 2016 build frp solution {Exclusive}
try 1000% solve...
Old 07-17-2016, 10:59   #5 (permalink)
Member: 2517404
Thanks Meter: 8
not the same phone . Is different phone what you posted
Old 07-17-2016, 11:09   #6 (permalink)
Member: 1118550
Thanks Meter: 31
prosses same i solve different phones a800i,g928g etc
Old 07-17-2016, 23:54   #7 (permalink)
Member: 2517404
Thanks Meter: 8
Anyone solved it for the G920t?
Old 07-17-2016, 23:55   #8 (permalink)
Member: 2517404
Thanks Meter: 8
Originally Posted by girish3672 View Post
how sure are you? dont say 100% if not tested on this model
Old 07-17-2016, 23:58   #9 (permalink)
Member: 1994657
Thanks Meter: 91
first remove frp, flash old sboot file, then fix drk.
Old 07-18-2016, 02:02   #10 (permalink)
markhaines1985's Avatar
Member: 2532914
Thanks Meter: 797
Here is how you remove FRP on G920T PF1:
1. Put phone into download mode.
2. Open odin and select BL tab and flash Eng_Sboot (Download Here)
3. Put phone back into download and wipe FRP with Z3X
4. Put phone back into download.
5. Select BL tab in Odin and flash Stock_Sboot (Download Here)
FRP REMOVED!!!
The Following 54 Users Say Thank You to markhaines1985 For This Useful Post:
Old 07-18-2016, 18:41   #11 (permalink)
tito millo's Avatar
Member: 390642
Sonork: 100.1573430
Thanks Meter: 2,474
FRP REMOVED!!!
Thanks bro this is the only solution that worked for me.
Br,
Tito Millo
The Following 4 Users Say Thank You to tito millo For This Useful Post:
Old 07-19-2016, 00:36   #12 (permalink)
Member: 1328247
Thanks Meter: 2
Thanks worked like a charm !!!!!
Old 07-19-2016, 05:07   #13 (permalink)
Member: 2517404
Thanks Meter: 8
just tried it but look
Software version: 26.0
Searching Samsung USB Flash Interface... detected COM4
Done with Samsung Tool PRO v.26.0
FRP REMOVED!!![/QUOTE]
The Following User Says Thank You to WirelessChamp For This Useful Post:
Old 07-19-2016, 05:20   #14 (permalink)
Member: 2517404
Thanks Meter: 8
nevermind
flashed it on z3x and worked ! thanks man ! youre the best
Old 07-19-2016, 13:27   #15 (permalink)
Member: 1834175
Thanks Meter: 33
Hello bro
any one can help to unlock g920t 6.0.1 pf1?
CAN I USE SBOOT Engineer TO MAKE DOWNGRADE ?
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Page generated in 0.37762 seconds with 7 queries
