03-14-2016, 08:58 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | G920T cert file failed BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-G920T Software version: 24.6 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G920T Android version: 5.1.1 Product code: SM-G920TZKATMB Phone version: G920TUVS3DOJC PDA version: G920TUVS3DOJC CSC version: G920TTMB3DOJC CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone S/N: R58G4107SLD Modem board: SHANNON333 RF cal date: 20150417 IMEI: Checking Super user right... true Initialization AT RIL... OK Checking certificate file... OK KEY ID: 0346 Check version... OK Initializating zTool... error (0) Done with Samsung Tool PRO v.24.6 plz how can i solved this proble:? |
The Following 4 Users Say Thank You to hippolyte85 For This Useful Post: |
