11-03-2016, 13:27 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Cambodia
Member: 59030 Status: Offline Thanks Meter: 165 | G920T Repair DRK Done, Save Phone. Operation: Repair DRK Selected model: SM-G920T Software version: 26.8 Checking local file... not found Searching server... OK Downloading file... OK Checking local file... OK Searching USB Flash interface... detected COM3 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G920TUES5DPI2 Platform: exynos7420 Boot serial: 1015faf1616d1905 Product board: zerolte Initializating zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... OK Checking DRK status... Repairing DMVT key... OK Rebooting phone... OK Repair DRK done Done with Samsung Tool PRO v.26.8 |
03-30-2018, 18:59 | #2 (permalink) |
Banned Join Date: Mar 2008
Member: 731937 Status: Offline Thanks Meter: 6 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on the phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair DRK Selected model: SM-G920T Software version: 31.0 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM31 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Recovery build version: 6.0.1 Boot version: G920TUES5EQL1 Platform: exynos7420 Boot serial: 06157df67a78e527 Product board: zeroflte Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... NG! Writing DRK... error () Done with Samsung Tool PRO v.31.0 |
