10-29-2017, 12:30 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Alger Age: 57
Member: 295459 Status: Offline Thanks Meter: 68 | SM-G920T Security damaged Code: Waiting ADB device... OK Reading phone info... Model: SM-G920T Android version: 7.0 Product code: Phone version: G920TUVU5FQG3 PDA version: G920TUVU5FQG3 CSC version: G920TTMB5FQG3 CSC country code: USA CSC sales code: TMB HW version: Phone SN: R58GC1M1Y4L Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-07-01 RF cal date: IMEI: 350000000000006 Checking Super user right... true Reading NV data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.29.5 |
The Following User Says Thank You to GSMTOPSUD For This Useful Post: |
10-29-2017, 16:56 | #4 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Tunisia Age: 43
Member: 40632 Status: Offline Sonork: 98231 Thanks Meter: 1,658 | just write this nv data file then repair imei or write cert file. I hope that this file will help many people here because no one have shared nv data for g920t in this forum. |
The Following 64 Users Say Thank You to midou01 For This Useful Post: |
03-17-2018, 18:57 | #9 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | Quote:
Operation: Write CERT Selected model: SM-G920T Software version: 31.0 Waiting ADB device... OK Reading phone info... Model: SM-G920T Android version: 7.0 Product code: Phone version: G920TUVS6FRA3 PDA version: G920TUVS6FRA3 CSC version: G920TTMB6FRA3 CSC country code: USA CSC sales code: TMB HW version: Phone SN: Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-01-01 RF cal date: IMEI: 350000000000006 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 68 7A 0E D6 06 00 00 00 00 00 00 00 00 00 00 Calculating... error Security damaged (hmac mismatch) Done with Samsung Tool PRO v.31.0 | |
03-17-2018, 19:08 | #10 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
03-17-2018, 19:20 | #11 (permalink) | |
03-17-2018, 19:59 | #12 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | The problem is that having the binary 6 firmware that you have installed in the phone there is no 'possibility to downgrade because all versions of android 7 with older security patches have the binary 5 and does not allow you to downgrade of the firmware on the model g920t if you go to see on sammobile the firmware versions of android 7 with older security patch level have the binary 5 you could try to install a firmware combination to downgrade to the android version 7 with binary 5 but it is risky and it can damage the phone unfortunately with the latest updates samsung has closed the ability to write the certificate for that even writing the nv file and then trying to write the certificate or using the patch cert is not successful |
03-17-2018, 20:08 | #13 (permalink) | |
03-17-2018, 20:18 | #14 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | To write the certificate you have no alternative you need to downgrade even for the issue of writing the file nv data having samsung closed the possibility of this operation in the security of the latest security patches I wrote you in the first post to downgrade if there were firmware with binary 6 having a sammobile guard on there is only the binary 5 for downgrading you can try to install a firmware combination and flash in 4 files of the stock firmware with older security patches but it is risky otherwise you have to wait that the z3x team comes up with an update for the new security for writing the cert and the patch cert |
03-17-2018, 20:23 | #15 (permalink) | |
NV Data and cert write function perfectly fine on binary 6. My original post was to show that after writing the nv data file that was posted by someone earlier, there is now a new error that I'm trying to fix | |
The Following User Says Thank You to namos23 For This Useful Post: |
