01-11-2017, 19:02 | #1 (permalink) |
Freak Poster Join Date: Sep 2014
Member: 2265024 Status: Offline Thanks Meter: 11 | G925A 6.0.1 FRP / Samsung Account. Done, but no way to reset? I have a G925A which I have done the "Reset FRP/React/EE" on Z3X. shows success (i have posted logs). Phone shows to home screen, but when I go to reset, it does not let me. Operation: Reset FRP/React/EE Selected model: SM-G925A Software version: 27.7 Searching Samsung USB Flash interface... COM86 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.7 The phone previously had a samsung account. Currently phone is running 6.0.1 with built PF1. Any solution to this ? Thank You |
01-12-2017, 06:49 | #2 (permalink) |
Freak Poster Join Date: May 2015 Location: Los Angeles Age: 29
Member: 2400231 Status: Offline Thanks Meter: 124 | Boot phone to download mode, if you see reactivation lock is off then you can reset the phone in recovery mode without any risk. Enable OEM unlock under developer settings to prevent being FRP locked while doing it first. |
01-12-2017, 23:10 | #6 (permalink) |
Freak Poster Join Date: Aug 2013 Location: El Pais de las Maravillas.
Member: 1994657 Status: Offline Thanks Meter: 93 | primero haz un hard reset o wipe y luego selecciona el modelo g920p y haz el frp reset, luego espero que suba tardara tiempo, pero cuando suba iniciara en la pantalla de inicio normal, saltara la configuracion de inicio, cuando termine de subir abres el google play y pones tu cuenta de google, luego haces el reset por dentro |
01-13-2017, 00:29 | #7 (permalink) | |
Member: 2265024 Status: Offline Thanks Meter: 11 | Quote:
"Pero tiene una cuenta Samsung, no una cuenta de Google. He puesto en una cuenta de google en él ahora mismo, pero todavía no me deja restablecer. " | |
01-13-2017, 19:06 | #10 (permalink) | |
Member: 1994657 Status: Offline Thanks Meter: 93 | Quote:
