12-27-2016, 21:11 | #1 (permalink) | |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 327 | G925F 35000000000006 imei fix new security august 2016 Problem Any way to repair imei for security august 2016 i tried repair efs then writ cert and writ EFS then cert but always fail Quote:
12-28-2016, 02:14 | #4 (permalink) |
Insane Poster Join Date: Sep 2014 Location: Venezuela Age: 29
Member: 2262368 Status: Offline Thanks Meter: 57 | Hi friend, i hope this help for your problem solution, first download this FACTORY BINARY COMBINATION_OXA_FA50_G925FXXU4APF1_OXA4APF1.zip because your phone is in BINARY 4 need combination with BINARY 4. Steps for repair: 1. Flash the full combination firmware using Z3X. 2. after phone flash successfull, reboot in download mode and flash Custom recovery TWPR (twrp_5.1.1_edge.tar) this is the only twpr that will work with that firmware, after that use supersu zip to root phone. 3. with the phone rooted use samsung tool 25.8 to repair imei and patch cert or write cert. then flash stock firmware again. PD: if in step 3 z3x say security damaged try to write your efs then make the procedure again. |
The Following User Says Thank You to jesusbritto1 For This Useful Post: |
