08-06-2016, 03:07 | #1 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 215288 Status: Offline Thanks Meter: 65 | G925F 6.0.1 the latest security ? ---------------------------------------------- Searching Samsung modem... detected COM265 Reading phone info... OK Model: SM-G925F AP Version: G925FXXS4DPG2 CSC Version: G925FBTU3DPD2 CP Version: G925FXXS4DPG1 Product code: XXXXXXXXXXXXXX Phone S/N: 0316035008a22904 Imei: 350000000000006 Unique number: 0316035008A22904 Reading data from phone... error (0) Done with Samsung Tool PRO v.26.3.1 |
08-06-2016, 08:02 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
if we will found solution we will add to next updates. | |
The Following 2 Users Say Thank You to blang For This Useful Post: |
08-13-2016, 23:41 | #5 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2585414 Status: Offline Thanks Meter: 2 | i took it to a tech guy. he succeeded to write SN and IMEI and got the phone to work again although i was not the original sn or imei it worked. as soon as i got it, i rooted it and the problem happend again. tried to call that tech guy again but hes angry at me for destroying hes work haha i will try to find out what excecly he did and post here |
08-18-2016, 11:31 | #6 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 44
Member: 91607 Status: Offline Thanks Meter: 41 | flash this software https://www.androidfilehost.com/?fid=24671318762849159 root your tel CF-Auto-Root-zerolte-zeroltexx-smg925f 6.0.1 wirte cert done |
08-28-2016, 00:59 | #8 (permalink) |
Member: 2585414 Status: Offline Thanks Meter: 2 | HI. I've tried what you guys suggested but still problem exist. Generate and check client proof... OK Verify proof by client... OK Reading data... error (8) Done with Samsung Tool PRO v.26.3 as far as i got is to imei 3500000006 and SN none Tried write cert - Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (8) Done with Samsung Tool PRO v.26.3 tried write EFS - OK IMEI - NULL SN - TURN BACK tO NORMAL tried to write cert again - same error tried to write NV_DATA - OK still the same. SN - ok IMEI - NULL tried repair only IMEI Searching Samsung modem... not found Done with Samsung Tool PRO v.26.3 tried patch certificate - Initializating zTool... OK Running zTool, please wait... error (7.7.8) Current version can not be patched Done with Samsung Tool PRO v.26.3 tried to lower modem to OJ1 with odin - ok still same SN- ok IMEI - NULL tried to reset EFS - OK SN- NULL IMEI - NULL TRIED TO WRITE EFS AGAIN -OK SN - OK IMEI - NULL tried write cert again Generate and check client proof... OK Verify proof by client... OK Reading data... error (8) Done with Samsung Tool PRO v.26.3 what else can i do ? |
