Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2009
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 210 | G925F Modem For Unlock Need modem to downgrade so I can unlock this handset Software version: G925FXXU4DPJG CSC version: G925FVFG4DPJG Modem version: G925FXXU4DPIT Regards |
![]() | #3 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,449 | Quote:
https://www.androidfilehost.com/?fid=745425885120702297 | |
The Following User Says Thank You to gcceleghg For This Useful Post: |
![]() | #8 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Sep 2015 Location: SSG COMMONDO Age: 23
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 543 | flash this firmware and click read codes or unlock https://www.androidfilehost.com/?fid=673368273298947417 |
![]() | #9 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2013
Member: 1908127 Status: Offline Thanks Meter: 6 | Quote:
FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G925F Software version: 28.1 File analysis... Ok Total file size: 0xDC8E9850 (3528 Mb) Searching USB Flash interface... COM16 detected Setup connection... Ok Reading PIT from phone... Ok Sending sboot.bin... error timeout It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-G925F" "Sending sboot.bin error timeout" - Пошук Google Done with Samsung Tool PRO v.28.1 | |
![]() | #10 (permalink) |
Member: 1908127 Status: Offline Thanks Meter: 6 | UNLOCK INSTRUCTIONS: New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-G925F Software version: 28.1 Searching Samsung modem... detected COM15 Reading phone info... Ok Model: SM-G925F AP version: G925FXXS5DQC1 CSC version: G925FBTU5DQA2 CP version: G925FXXU5DPL3 Product code: SM-G925FZDABTU Phone SN: R58G90X7NGM Unique number: 0715F7A9E161013A Reading IMEI... Ok IMEI: 353621072919406 (SIGN: OK) Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.28.1 |
![]() | #11 (permalink) |
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 543 | 3/19/2017 5:59:00 PM ] Waiting ADB device... Ok [ 3/19/2017 5:59:00 PM ] Reading phone info... [ 3/19/2017 5:59:00 PM ] Model: SM-G925F [ 3/19/2017 5:59:00 PM ] Android version: 6.0.1 [ 3/19/2017 5:59:00 PM ] Product code: SM-G925FZDAO2U [ 3/19/2017 5:59:00 PM ] Phone version: G925FXXU5DPL3 [ 3/19/2017 5:59:00 PM ] PDA version: G925FXXU5DQA7 [ 3/19/2017 5:59:00 PM ] CSC version: G925FBTU5DQA2 [ 3/19/2017 5:59:00 PM ] CSC country code: UK & IRE [ 3/19/2017 5:59:00 PM ] CSC sales code: BTU [ 3/19/2017 5:59:00 PM ] HW version: MP 0.700 [ 3/19/2017 5:59:00 PM ] Phone SN: [ 3/19/2017 5:59:00 PM ] Chip name: EXYNOS7420 [ 3/19/2017 5:59:00 PM ] Modem board: SHANNON333 [ 3/19/2017 5:59:00 PM ] RF cal date: 20160505 [ 3/19/2017 5:59:00 PM ] IMEI: [ 3/19/2017 5:59:00 PM ] Checking Super user right... true [ 3/19/2017 5:59:00 PM ] Reading NV data... Ok [ 3/19/2017 5:59:00 PM ] Checking NV data... Ok [ 3/19/2017 5:59:00 PM ] Initialization zTool... Ok [ 3/19/2017 5:59:00 PM ] Running zTool, please wait... Ok [ 3/19/2017 6:00:00 PM ] HWID: E8 9B D1 AE F4 04 00 00 00 00 00 00 00 00 00 00 [ 3/19/2017 6:00:00 PM ] Calculating... Ok [ 3/19/2017 6:00:00 PM ] Unlocking... Ok [ 3/19/2017 6:00:00 PM ] Writing NV data... Ok [ 3/19/2017 6:00:00 PM ] Rebooting phone... Ok [ 3/19/2017 6:00:00 PM ] Unlock done samsung tool v27.8 |
![]() | #13 (permalink) | |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 210 | Quote:
have tried this but still error | |
