04-21-2017, 17:49 | #1 (permalink) |
Junior Member Join Date: Dec 2015 Location: UCA
Member: 2495156 Status: Offline Thanks Meter: 5 | G925F no imei 7.0 Unknow baseband i was thinking that the firmware cause it but it wasnt the firmware, i try 21 firmware and the same happend alwayse help me REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair Selected model: SM-G925F Software version: 28.1 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G925F Android version: 7.0 Product code: Phone version: PDA version: G925FXXU5EQBG CSC version: G925FVFG5EQC2 CSC country code: Switzerland CSC sales code: SWC HW version: Phone SN: RF8G40E0N3F Chip name: EXYNOS7420 Modem board: Security patch: 2017-02-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Can not detected modem type Done with Samsung Tool PRO v.28.1 |
The Following 2 Users Say Thank You to uca For This Useful Post: |
04-21-2017, 19:47 | #4 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro it will not boot up your file binary is 3 and the phone has binary 5 try combination and see if the baseband and imei is ok then it is software error if it doesn't show imei and baseband it is baseband hardware defect B.R PLEASE PRESS THANKS ❤BUTTON IF THE POST IS HELPFULL FOR YOU |
The Following 4 Users Say Thank You to souma_k For This Useful Post: |
05-20-2017, 13:34 | #5 (permalink) |
Insane Poster Join Date: Apr 2014 Location: Shop # 34 HafeeZ Center,
Member: 2161392 Status: Offline Sonork: 100.1677520:hafiz Thanks Meter: 50 | g925f 7.0 imei repair 10000000000000000 ok Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 7.0 Product code: Phone version: G925FXXU5EQCQ PDA version: G925FXXU5EQDH CSC version: G925FVIR5EQD7 CSC country code: UK CSC sales code: VIR HW version: Phone SN: RF8G5207ABB Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2017-04-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 51 1C 4F E6 05 00 00 00 00 00 00 00 00 00 00 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.28.1 circuit city .hafeez centre.shop# g.34 hafiz.jahangir/ph.009203214442394 |
The Following User Says Thank You to jahangir_123 For This Useful Post: |
