12-12-2016, 13:41 | #1 (permalink) |
Crazy Poster Join Date: Jan 2016
Member: 2523384 Status: Offline Thanks Meter: 0 | g925f patc cert fail error (7.7.8) Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-G925F Software version: 27.5 Waiting ADB device... Ok Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: SM-G925FZWADBT Phone version: G925FXXU4BPF1 PDA version: G925FXXS4DPJ5 CSC version: G925FDBT4DPIU CSC country code: Germany CSC sales code: DBT HW version: MP 0.600 Phone SN: R58G60DGQZD Modem board: SHANNON333 RF cal date: 20150606 IMEI: Checking Super user right... true Initialization zTool... Ok Running zTool, please wait... error (7.7.8) Current version can not be patched Done with Samsung Tool PRO v.27.5 |
