04-30-2016, 08:54 | #1 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Romania
Member: 1979249 Status: Offline Thanks Meter: 63 | G925F reactivation lock error - phone stuck [ 4/30/2016 10:05:00 AM ] Selected model: SM-G925F [ 4/30/2016 10:05:00 AM ] Software version: 25.2 [ 4/30/2016 10:05:00 AM ] [ 4/30/2016 10:05:00 AM ] Searching Samsung USB Flash Interface... detected COM71 [ 4/30/2016 10:05:00 AM ] Setup connection... OK [ 4/30/2016 10:05:00 AM ] Reading PIT from phone... OK [ 4/30/2016 10:05:00 AM ] Searching FRP lock... OK [ 4/30/2016 10:05:00 AM ] Erasing FRP... error ---- After reboot phone stuck and the exclamation mark appear. Using Smart Switch Emergency recovery don't work because i need to enter previous pin code. What to do?Thank's. |
04-30-2016, 09:13 | #2 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Hello flash old sboot and reset frp will work but if it is android 6.0.1 you need to flash sboot of the actual soft (sboot 6.0.1) Sent from my SM-G928F using Tapatalk |
The Following 2 Users Say Thank You to souma_k For This Useful Post: |
04-30-2016, 10:00 | #4 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | From recovery mode if it enters in recovery mode any ways sboot is from 5.1.1 that can be reset frp Sent from my GT-I9500 using Tapatalk |
04-30-2016, 10:02 | #5 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | The phone should be on download mode to flash sboot Sent from my GT-I9500 using Tapatalk |
The Following User Says Thank You to souma_k For This Useful Post: |
04-30-2016, 10:07 | #7 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Sboot and modem if you need to patch cert Sent from my GT-I9500 using Tapatalk |
04-30-2016, 10:24 | #8 (permalink) |
Member: 1979249 Status: Offline Thanks Meter: 63 | <ID:0/007> Added!! <ID:0/007> Odin engine v(ID:3.1005).. <ID:0/007> File analysis.. <ID:0/007> SetupConnection.. <ID:0/007> Initialzation.. <ID:0/007> Get PIT for mapping.. <ID:0/007> Firmware update start.. <ID:0/007> SingleDownload. <ID:0/007> sboot.bin <ID:0/007> NAND Write Start!! <ID:0/007> FAIL! --- Don't seem to work... |
04-30-2016, 19:09 | #11 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2556868 Status: Offline Thanks Meter: 0 | Same **** I have just recieved a phone in exact same condition...Same error with sam pro cant downgrade or flash sboot. ...Latest firmware doesnt support FRP unlock ? The phone apparantley has been upgraded after lock..there are also B:3 K:2 S:2 meaning custom binary kerne... had been tried and tripped by some one already |
04-30-2016, 19:59 | #12 (permalink) |
Member: 1979249 Status: Offline Thanks Meter: 63 | I update it with Smart Switch and now phone is on but with reactivation lock still on. I was told by souma_k to flash old sboot for 5.1.1,reset FRP/Reactivation,after that phone will be in bootloop,and than again flash sboot for 6.0.1 and will be ok.Anybody tried this?I'm afraid i could brick the phone. |
04-30-2016, 20:03 | #13 (permalink) | |
Member: 2556868 Status: Offline Thanks Meter: 0 | Quote:
Sent from my SM-G925F using Tapatalk | |
04-30-2016, 22:05 | #14 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro i tried it and it worked with me 100% after flashing sboot 5.1.1 phone stock on galaxy s6 edge after frp reset done flash BL 6.0.1 if u have 4 files firmware and wipe data the phone will boot normally . Sent from my GT-I9500 using Tapatalk |
