04-02-2016, 20:56 | #1 (permalink) |
Freak Poster Join Date: Jun 2015 Location: Eastern U.S.
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | G925P S6 Edge Sprint Unlock Marshmallow 6.0.1 PB6 Solution Files Inlcuded SO you need to root, and every other post discusses the possibility of a kernel floating around for PB6, but I am not going to send you on a wild goose chase looking for the twrp recovery, the kernel, and the supersu zip to flash. Here are the files bundled in a zip for you. PB6Marshmallow************** Once downloaded, first make sure to enable developer's options. Than enable OEM unlocking and USB debugging. After that, copy the kernel and the supersu zip to the root of your sd storage. Flash the TWRP recovery, boot into TWRP recovery, flash both the kernel zipkerne1l.zip and Beta-SuperSU-v2.68, then reboot, make sure supersu is enabled, then run the unlock once again from Z3X, it will work flawlessly. Feel free to give a thanks or a donation, I post as many solutions as I can. Thank you, oh and before I forgot here is the log showing it works: Operation: Unlock SPRNT Selected model: SM-G925P Software version: 25.0 Waiting ADB device... OK Reading phone info... Model: SM-G925P Android version: 6.0.1 Product code: Not Active Phone version: G925PVPU3CPB6 PDA version: G925PVPU3CPB6 CSC version: G925PSPT3CPB6 CSC country code: USA CSC sales code: SPR HW version: G925P.02 Phone S/N: 00000000000 Modem board: MDM9635M RF cal date: 2015.06.11 IMEI: Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done |
The Following 89 Users Say Thank You to CastleSamsung12 For This Useful Post: |
04-03-2016, 01:06 | #3 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | Out of 100 downloads, I received one thank you... Not going trough all this effort next time |
The Following 6 Users Say Thank You to CastleSamsung12 For This Useful Post: |
04-03-2016, 03:40 | #6 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | Anyone with UART capability that wants the command to remove the Sprint splash screen, no root needed, PM me. |
The Following 7 Users Say Thank You to CastleSamsung12 For This Useful Post: |
04-03-2016, 03:48 | #7 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | AT+PRECONFG=2,XAS There it is, just don't forget to hit thanks on your way out! |
The Following 16 Users Say Thank You to CastleSamsung12 For This Useful Post: |
04-03-2016, 15:28 | #9 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | I have more but do hold the custom or purchased ones back. Not right to give away work either. There has to be a balance. |
The Following 5 Users Say Thank You to CastleSamsung12 For This Useful Post: |
04-03-2016, 21:54 | #11 (permalink) |
Member: 2417116 Status: Offline Sonork: 100.1671776 Thanks Meter: 273 | It's not always the software requiring root privilege, sometimes the phone requires su in order to access certain commands, and until they update or change requirements for unlock, Samsung has patched their firmware in a way to stop Z3X's GSM unlock on Marshmallow. If you read your logs as you run these operations, you'll have a bit more insight into these questions. |
The Following 2 Users Say Thank You to CastleSamsung12 For This Useful Post: |
04-04-2016, 03:15 | #13 (permalink) |
Freak Poster Join Date: Apr 2006 Location: jamaica
Member: 260210 Status: Offline Thanks Meter: 26 | if i get a lock phone from sprint with marshmellow GCPROKEY unlock without root 100% working but if i get one that was unlocked before and updated when i relock and unlock no service have to downgrade thanks for this method |
04-04-2016, 07:48 | #14 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: PAKISTAN Age: 34
Member: 1082907 Status: Offline Sonork: 100.1606954 Thanks Meter: 342 | Quote:
