03-03-2016, 13:08 | #19 (permalink) |
Freak Poster Join Date: Feb 2016 Location: GJ, India
Member: 2527669 Status: Offline Sonork: 100.1672079 Thanks Meter: 33 | 5.1.1 - s6, s6 edge+, s6 edge and note 5 not work in 24.5 tool UNLOCK NOT WORK IN Z3X SAMSUNG PRO TOOL 24.4 VERSION. SAMSUNG S6 SM-G920T, S6 EDGE SM-G925T, S6 EDGE+ SM-G928T AND NOTE 5 SM-N920T = 5.1.1 ANDROIND VERSION FOR ALL. I HAVE ROOTED MY ALL PHONE USING ARTER97.COM METHOD. BUT ITS NOT UNLOCK NOT WORK IN Z3X SAMSUNG PRO TOOL 24.4, ITS GIVING ME ERROR. ---- NOT UNLOCKED -- Operation: Unlock Selected model: SM-G928T Software version: 24.5 Waiting ADB device... OK Reading phone info... Model: SM-G928T Android version: 5.1.1 Product code: SM-G928TZKATMB Phone version: G928TUVS2COKC PDA version: G928TUVS2COKC CSC version: G928TTMB2COKC CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone S/N: R58G71BKJSY Modem board: SHANNON333 RF cal date: 20150723 IMEI: Checking Super user right... true Initialization AT RIL... error (0) Done with Samsung Tool PRO v.24.5 --- HOW ROOTED--- Files needed to do the S6 Edge+ / Note 5 root 1) Samsung drivers - Download it here 2) Odin 3.10.6 - Download it here 3) Custom kernel and recovery - Download it here (Very important chose only the one for your device model!) :- 4) SuperSU - Download it here Step by step root tutorial for Galaxy S6 Edge+ Note 5 etc 1. Download the files mentioned above. While downloading the others might not be a problem,when downloading the custom kernel and recovery you need to enter to the last version available of the kernel,currently is 11.0 and from there select your device. For example if you have a Galaxy S6 Edge+ G928T T-Mobile choose g928tw8. And from there download the arter97-kernel-g928tw8-11.0.zip and the arter97-recovery-g928tw8-11.0-philz_touch_6.59.0.tar.md5 (the recovery with tar.md5 at end so can flash it by Odin) 2. Install the Samsung drivers and extract the files from Odin3_v3.10.7.zip 3. Connect the phone in normal mode and transfer on the root of your phone or somewhere easy to find on your phone the Supersu update file UPDATE-SuperSU-v2.46.zip and the custom kernel arter97-kernel-g928tw8-11.0.zip 4. On your phone go to Settings/About Device and tap 7 times on the Build number till will show on screen "You are now a developer" 5. From Settings/Developer options enable Usb debugging and Enable OEM unlock (if your phone has that option) 6. From Settings/Security verify that Reactivation lock not to be selected, if it is deselect it 7. Turn off the phone, then hold Home+Power+Volume down till you get to a Warning screen, after that press Volume Up to Continue and when you see "Downloading" on screen you know you are in Download mode 8. Open Odin and select for AP the custom recovery from Philz_touch arter97-recovery-g928tw8-11.0-philz_touch_6.59.0.tar.md5 and also from The Options tab deselect the option Auto Reboot 9. Connect the phone to computer and when the COM box from Odin becomes blue press Start button 10. When you see on Odin "PASS" can disconnect phone from computer and hold Home+Power+Volume Up to boot in recovery-since in passing from Download mode might take a bit longer 11. Once you booted in the custom recovery (should be written Philz Touch on the top left ), select the Option "Install zip" and browse to the place from your phone where you in Step 3 you transferred the 2 files and select arter97-kernel-g928tw8-11.0.zip ,then Yes-Install again to confirm the installation. 12. Do exact like on step 11 to install UPDATE-SuperSU-v2.46.zip, then select the option Reboot System now 14. Phone will reboot and you will find SuperSu app installed and if it opens without any error then you have the confirmation the phone is successfully rooted. |
03-08-2016, 15:11 | #20 (permalink) |
Junior Member Join Date: Dec 2013 Location: AHMEDABAD,GUJARAT
Member: 2090482 Status: Offline Sonork: 100.1626980 Thanks Meter: 0 | [ 08/03/2016 5:42:00 PM SM-N920T Unlock ] Operation: Unlock [ 08/03/2016 5:42:00 PM SM-N920T Unlock ] Selected model: SM-N920T [ 08/03/2016 5:42:00 PM SM-N920T Unlock ] Software version: 24.6 [ 08/03/2016 5:42:00 PM SM-N920T Unlock ] [ 08/03/2016 5:42:00 PM SM-N920T Unlock ] Waiting ADB device... OK [ 08/03/2016 5:42:00 PM SM-N920T Unlock ] Reading phone info... [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Model: SM-N920T [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Android version: 5.1.1 [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Product code: SM-N920TZWATMB [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Phone version: N920TUVS2COKC [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] PDA version: N920TUVS2COKC [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] CSC version: N920TTMB2COKC [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] CSC country code: USA [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] CSC sales code: TMB [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] HW version: REV0.2 [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Phone S/N: RF8G725ALBV [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Modem board: SHANNON333 [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] RF cal date: 20150727 [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] IMEI: [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Checking Super user right... true [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Initialization AT RIL... OK [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Check version... OK [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Initializating zTool... OK [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Running zTool, please wait... OK [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Reading nv data... OK [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Checking NV data... OK [ 08/03/2016 5:43:00 PM SM-N920T Unlock ] Calculating... OK [ 08/03/2016 5:44:00 PM SM-N920T Unlock ] Writing nv data... OK [ 08/03/2016 5:44:00 PM SM-N920T Unlock ] Rebooting phone... OK [ 08/03/2016 5:44:00 PM SM-N920T Unlock ] Unlock done |
03-08-2016, 23:41 | #21 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076 Status: Offline Sonork: 100.1663298 Thanks Meter: 185 | I unlock those models without any problem by z3x with latest android version below 6.0.1 No problem at all please use stock firmware and then use correct root no problem for unlocking Br Shahzaib Jahangir |
03-09-2016, 07:23 | #23 (permalink) |
No Life Poster Join Date: Dec 2005 Location: PAKISTAN Age: 35
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | Operation: Unlock Selected model: SM-G925T Software version: 24.6 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 5.1.1 Product code: SM-G925TZKATMB Phone version: G925TUVU3DOJ7 PDA version: G925TUVU3DOJ7 CSC version: G925TTMB3DOJ7 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone S/N: R58G321BE5J Modem board: SHANNON333 RF cal date: 20150328 IMEI: Checking Super user right... true Initialization AT RIL... OK Check version... OK Initializating zTool... error (0) Done with Samsung Tool PRO v.24.6 |
05-02-2016, 05:56 | #27 (permalink) |
Junior Member Join Date: May 2016
Member: 2567311 Status: Offline Thanks Meter: 6 | i need help i keep getting this error ?1 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 Product code: SM2G925TZDATMB Phone version: G925TUVU3EPD1 PDA version: G925TUVU3EPD1 CSC version: G925TTMB3EPD1 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone S/N: R58G7166SMN Modem board: SHANNON333 RF cal date: 20150722 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (9) Done with Samsung Tool PRO v.25.2 |
07-27-2016, 15:47 | #28 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1467082 Status: Offline Thanks Meter: 0 | Operation: Write CERT Selected model: SM-G925T Software version: 26.2 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 Product code: Phone version: G925TUVU4EPF1 PDA version: G925TUVU4EPF1 CSC version: G925TTMB4EPF1 CSC country code: USA CSC sales code: TMB HW version: Phone S/N: 00000000000 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (9) Done with Samsung Tool PRO v.26.2 plece send salution z3x team |
08-19-2016, 21:49 | #29 (permalink) |
No Life Poster Join Date: Oct 2002 Location: tunisia
Member: 16625 Status: Offline Sonork: 1578753 Thanks Meter: 161 | G925F i had to unlock it 2 times to be really unlocked Operation: Unlock Selected model: SM-G925F Software version: 26.4 Searching Samsung modem... detected COM63 Reading phone info... OK Model: SM-G925F AP Version: G925FXXU3DPDB CSC Version: G925FFTM3DPDB CP Version: G925FXXU3DPCF Product code: SM-G925FZDAFTM Phone S/N: R58H11588PK Imei: 356421----------- Unique number: 1115FBAD40C63105 Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.4 |
09-25-2016, 10:13 | #30 (permalink) |
Junior Member Join Date: Nov 2013 Location: faisalabad
Member: 2060840 Status: Offline Thanks Meter: 2 | Operation: Unlock Selected model: SM-G925T Software version: 26.7 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 Product code: Phone version: G925TUVS4EPH2 PDA version: G925TUVS4EPH2 CSC version: G925TTMB4EPH2 CSC country code: USA CSC sales code: TMB HW version: Phone S/N: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (9) Done with Samsung Tool PRO v.26.7 |
