08-31-2016, 16:44 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Albania -Durres
Member: 154346 Status: Offline Thanks Meter: 37 | G925t imei 350000000006 solution |
08-31-2016, 17:43 | #4 (permalink) |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | can t repair with z3x BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-N920A Software version: 26.6 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 Product code: Phone version: G925TUVU4EPF1 PDA version: G925TUVU4EPF1 CSC version: G925TTMB4EPF1 CSC country code: USA CSC sales code: TMB HW version: Phone S/N: Modem board: SHANNON333 RF cal date: IMEI: Incorrect model selected. This may damage your phone. Continue? Yes Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (9) Done with Samsung Tool PRO v.26.6 |
08-31-2016, 17:58 | #5 (permalink) |
Insane Poster Join Date: Sep 2014 Location: Venezuela Age: 29
Member: 2262368 Status: Offline Thanks Meter: 57 | can be done with octopus and z3x, root and reset efs with z3x then use octopus to repair security when phone restarts, use write cert with octopus and make sure to write a G925T cert only, do not try to write a cert of the same key id like g925a or g925f because imei will be 350000000000006. after the imei was restored by the cert, repair drk with z3x wipe data, and reflash phone with the G925TUVU4EPF1 stock firmware, and you won't have any problems no more. |
