08-14-2018, 10:02 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Indonesia
Member: 901949 Status: Offline Thanks Meter: 50 | G925T imei repair failed it says security damaged it says imei 350000000000006 i tried to write cert failed, repair imei failed Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 PDA version: G925TUVU5EPK5 CSC version: G925TUVU5EPK5 Phone version: Product code: CSC country code: Germany CSC sales code: DTM Phone SN: R58G50DA6NM IMEI: HW version: RF cal date: Chip name: EXYNOS7420 Modem board: Security patch: 2016-11-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.33.5 |
08-14-2018, 11:13 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
NV data download https://mega.nz/#!LYgGXZIQ!ErnCsy2q8...oI0y1n4LiechHs | |
08-14-2018, 11:58 | #3 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | i got this after write NV and write cert from you thanks for your help on providing the cert Operation: Write CERT Selected model: SM-G925T Software version: 33.5 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 PDA version: G925TUVU5EPK5 CSC version: G925TTMB5EPK5 Phone version: G925TUVU5EPK5 Product code: CSC country code: USA CSC sales code: TMB Phone SN: IMEI: 350000000000006 HW version: RF cal date: Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2016-11-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 1A BB 2C 35 06 00 00 00 00 00 00 00 00 00 00 Calculating... error Security damaged (hmac mismatch) Done with Samsung Tool PRO v.33.5 |
08-14-2018, 12:05 | #4 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | Operation: Patch Certificate Selected model: SM-G925T Software version: 33.5 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 PDA version: G925TUVU5EPK5 CSC version: G925TTMB5EPK5 Phone version: G925TUVU5EPK5 Product code: CSC country code: USA CSC sales code: TMB Phone SN: IMEI: 350000000000006 HW version: RF cal date: Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2016-11-01 Boot Warranty bit: 1 Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.33.5 |
08-14-2018, 12:15 | #5 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | Operation: Repair Selected model: SM-G925T Software version: 33.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 PDA version: G925TUVU5EPK5 CSC version: G925TTMB5EPK5 Phone version: G925TUVU5EPK5 Product code: CSC country code: USA CSC sales code: TMB Phone SN: IMEI: 350000000000006 HW version: RF cal date: Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2016-11-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.33.5 |
08-14-2018, 12:16 | #6 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | Operation: Write CERT Selected model: SM-G925T Software version: 33.5 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 PDA version: G925TUVU5EPK5 CSC version: G925TTMB5EPK5 Phone version: G925TUVU5EPK5 Product code: CSC country code: USA CSC sales code: TMB Phone SN: IMEI: 350000000000006 HW version: RF cal date: Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2016-11-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.33.5 |
08-14-2018, 12:25 | #7 (permalink) | |
because I read three logs where you have the damaged security and a log of the program where you wrote the patch cert correctly | |
08-14-2018, 12:47 | #8 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | the cert write is never successful patch cert successful write NV successful but write cert never done did erase EFS already before write EFS and Cert baseband is not unknown imei is gone because i did factory data reset on menu |
08-14-2018, 12:59 | #10 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | if you do the patch cert it is normal that doing the factory reset remains unregistered on the network, strange that does not make you write the cert in conclusion if you patch cert the network remains instead writing the cert not z3x does not write it, but writing the patch Does the network work without making a factory reset of the phone? |
08-14-2018, 13:14 | #12 (permalink) | |
in practice, that you intend to belong to you but if you do the repair imei and the patch cert without doing the factory reset the imei remains at 350000000000006 | |
08-14-2018, 16:21 | #14 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | You wrote that after writing the nv data successfully the imei remains at 35000000006, and your serial number is gone, I have only asked you when you write the new imei and make the patch cert if you imei you still have 3500000006 or remains the code imei you wrote and the network works, it is normal that the serial number using another nv date does not remain the original |
08-14-2018, 17:10 | #15 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | 1. it was unlocked using root method (before imei is gone) 2. after factory data reset the device get locked again and the imei is changing to 350000000000006. 3. i'm don't have original cert backup, nv backup because i'm not the one who unlock it at the first time so what i was trying to do now, is to recover imei, after recover imei i have to unlock again the problem is now ... : 1. write NV from you (successful) 2. write cert from you (failed) 3. i tried doing imei repair (failed) 4. patch certificate (successful) after patch certificate successful i tried to unlock but it says Operation: Unlock Selected model: SM-G925T Selected port: COM51 SAMSUNG Mobile USB Serial Port Software version: 33.5 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 6.0.1 PDA version: G925TUVU5EPK5 CSC version: G925TTMB5EPK5 Phone version: Product code: CSC country code: USA CSC sales code: TMB Phone SN: IMEI: HW version: RF cal date: Chip name: EXYNOS7420 Modem board: Security patch: 2016-11-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... error (0 6) Done with Samsung Tool PRO v.33.5 i'm sure this because imei data is still not complete? do you have another cert? |
