08-31-2015, 11:55 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: paris france
Member: 1520741 Status: Offline Sonork: zboubdepanda Thanks Meter: 72 | G925T Stuck logo after write another EFS I have g925T 5.1.1 that i tried to root with g925t autoroot ... it failed and phone was stucking at Samsung logo, i did an firmware update with SmartSwitch and it worked but IMEI was gone to 3560000000 i tried to unlock with Z3X but got security error.... i've searched how to solve this problem and in another post a user said that it need to write another good EFS , so i DID with his EFS file but still same problem and SN have changed and i didnt make efs backup .... I tried again to update the device with SMARTSWITCH and now it STUCK ON SAMSUNG LOGO forever even with flash stock firmware even with put old or new SERIAL on smart it always stuck .... Can someone tell me how i can revive this S6edge please ? Thanks... |
08-31-2015, 13:20 | #3 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | try another efs EFS_SM-G925T_G925TUVU1AOCG__R58G31M6JRE_16-6-2015_15-2-38 - Download - 4shared for see what happen. |
The Following User Says Thank You to ghacks For This Useful Post: |
08-31-2015, 13:27 | #4 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Forget about other phone EFS for 5.1.1 phones. there are root key which is unique for each phone. |
The Following User Says Thank You to blang For This Useful Post: |
09-09-2015, 17:47 | #6 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Kanada
Member: 737720 Status: Offline Thanks Meter: 1,421 | That is Right. If u have a original efs then u can do something. But depend how u bkup ur efs. Or try flash with other rom so ur phone gonna be dead no power in this case u can change ur phone from samsung center becs they cant see that knox warranty is trip |
09-10-2015, 01:33 | #7 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Quote:
09-10-2015, 02:04 | #8 (permalink) | |
No Life Poster Join Date: Jan 2011 Location: Honduras
Member: 1488173 Status: Offline Thanks Meter: 194 | Here is your solution... Quote:
1.- flash stock firmware 5.1.1 through odin 2.-make hard reset 3.-flash this kernel: S6-UniBase_BOG8_v2.tar 4.- After this step phone will boot up but will have imei null or generic 5.-write efs backup, does not matter if is from another phone 6.-Now make direct unlock with z3x 7.-write cert and you are done *After this process you will have drk problems because you donīt have original efs backup, i mean you cannīt make stock restore or update because you will brick it again *i have solved imei null with this process *this info is tested by me Best Regards !! | |
The Following User Says Thank You to celumaster. For This Useful Post: |
09-10-2015, 04:43 | #9 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: Black Market Age: 39
Member: 1744748 Status: Offline Thanks Meter: 752 | Quote:
I can fix the DRK / boot loop issue... contact me if interested... | |
09-12-2015, 20:35 | #11 (permalink) |
Freak Poster Join Date: Nov 2014 Location: live in ASGARD
Member: 2299237 Status: Offline Thanks Meter: 47 | Fixed hello , this problem can fixed very easy. just flash phone with 4 files . if not boot write unikernel v8-002. or write twrp. it will work i fixed mine. |
