10-05-2016, 19:34 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | G9280 stuck after flash FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, hold Volume Down + Home + Power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G9280 Software version: 26.9 File analysis... OK Total file size: 0xBE1CEEC0 (3041 Mb) Searching USB Flash interface... COM17 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending cache.img... OK Sending modem.bin... OK Flashing done (time - 00:02:27) Done with Samsung Tool PRO v.26.9 |
