08-14-2016, 01:01 | #1 (permalink) |
Freak Poster Join Date: Dec 2012
Member: 1851293 Status: Offline Thanks Meter: 19 | G928A PG1 missing DRK Help |
08-14-2016, 03:32 | #2 (permalink) |
Freak Poster Join Date: May 2012 Location: Haiti, Port-Au-Prince, Carref.
Member: 1763284 Status: Offline Thanks Meter: 56 | Hi mate have u tried to repair by writing a new cert file over? It should be alright after. Sent from my LG-H631 using Tapatalk Last edited by Castle2k; 08-14-2016 at 03:36. Reason: Mistakes |
08-14-2016, 03:55 | #3 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | bro Good to go Quote:
21.9 i done but u cannot unlock it after u can use GCPRO KEY for unlock after its my method i done . BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 5. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-G925T Software version: 21.9 Checking certificate file... OK KEY ID: 0346 Waiting ADB device... OK Reading phone info... Model: SM-G925T Android version: 5.0.2 Product code: Phone version: G925TUVU4EPE8 PDA version: FA50_G925TUVU4APE1 thats my combinaison FW. CSC version: CSC country code: CSC sales code: HW version: Phone S/N: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initialization AT RIL... OK Checking MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0346 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.21.9 | |
The Following User Says Thank You to ghacks For This Useful Post: |
08-14-2016, 15:40 | #4 (permalink) | |
Member: 1851293 Status: Offline Thanks Meter: 19 | Quote:
08-19-2016, 00:30 | #9 (permalink) | |
Freak Poster Join Date: Mar 2009
Member: 996077 Status: Offline Thanks Meter: 19 | Quote:
