09-03-2016, 15:55 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | G928C stuck in logo after flash same FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G928C Software version: 26.6 File analysis... OK Total file size: 0x154C12B0 (340 Mb) Searching USB Flash Interface... detected COM15 Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:04:45) Done with Samsung Tool PRO v.26.6 may be need engboot or what i av tried combinason file but after error phone write "an error has occured while..." File analysis... OK Total file size: 0x688594A4 (1672 Mb) Searching USB Flash Interface... detected COM15 Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... error timeout It looks like you have a unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-G928C" "Sending system.img... error timeout" - Ïîøóê Google Done with Samsung Tool PRO v.26.6 |
The Following 2 Users Say Thank You to hippolyte85 For This Useful Post: |
05-01-2017, 10:04 | #2 (permalink) | |
Junior Member Join Date: Nov 2016
Member: 2650380 Status: Offline Thanks Meter: 0 | Quote:
same problem here.. did u solve it already?? | |
