02-02-2016, 13:14 | #1 (permalink) |
Freak Poster Join Date: Jun 2004
Member: 68705 Status: Offline Thanks Meter: 38 | g928f cert error UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Write CERT Selected model: SM-G928F Software version: 24.2 Waiting ADB device... OK Reading phone info... Model: SM-G928F Android version: 5.1.1 Product code: SM-G928FZKAXEU Phone version: G928FXXU2AOJ3 PDA version: G928FXXU2AOL2 CSC version: G928FXEU2AOL1 CSC country code: UK & IRE CSC sales code: XEU HW version: MP 0.500 Phone S/N: R58G91RS5VL Modem board: SHANNON333 RF cal date: 20150922 IMEI: Checking Super user right... true Initialization AT RIL... OK Checking certificate file... OK KEY ID: 0784 Check version... OK Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... Exception: Access violation at address 0040744F in module 'SamsungToolPRO.exe'. Read of address 082FC8BE Done with Samsung Tool PRO v.24.2 |
