10-18-2015, 14:29 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 643752 Status: Offline Thanks Meter: 10 | G928F write cert error Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 5. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-G928F Software version: 23.0 Waiting ADB device... OK Reading phone info... Model: SM-G928F Android version: 5.1.1 Product code: Phone version: G928FXXU1AOGH PDA version: G928FXXU1AOGM CSC version: G928FVFG1AOGO CSC country code: South Africa CSC sales code: XFV HW version: Phone S/N: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Checking certificate file... OK KEY ID: 0346 Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.23.0 what problem?how to do it |
10-19-2015, 09:28 | #5 (permalink) |
Member: 643752 Status: Offline Thanks Meter: 10 | i didnt have g928f working phone to read,anybody can help me?i was think is 23.0 version problem,becuse im use 23.0 write G925F cert some Checking NV data... error,use 22.5 write cert done. |
10-30-2016, 11:22 | #9 (permalink) |
No Life Poster Join Date: May 2009 Location: Bangladesh/USA/UK Age: 39
Member: 1033714 Status: Offline Sonork: 1640811:mothertelecom Thanks Meter: 91 | [QUOTE=linyex;11355870]BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 5. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-G92 give Waiting ADB device... OK Reading phone info... Model: SM-G928F Android version: 5.1.1 Product code: Phone version: G928FXXU1AOGH PDA version: G928FXXU1AOGM CSC version: G928FVFG1AOGO CSC country code: South Africa CSC sales code: XFV HW version: Phone S/N: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Checking certificate file... OK KEY ID: 0346 Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.23.0 help me g928f cert |
