07-29-2016, 23:13 | #1 (permalink) |
Freak Poster Join Date: Nov 2014
Member: 2291117 Status: Offline Thanks Meter: 34 | g930az frp reset? find a sboot file that i can flash so i can reset the FRP, please help and thank you |
07-31-2016, 04:11 | #7 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | Here is how you reset FRP on G930AZ 1. Put phone into download mode: 2. Then open custom odin. DO NOT use regualar odin. (Download here) 3. Select AP tab and select and flash Eng root file (Download here) 4. When phone comes back on wait for ADB drivers to install. 5. The run this .bat file (Download here) 6. If everything went right phone should automatically go back into download mode. 7. When back in download mode flash stock boot image. (Download Here) FRP REMOVED!!!! |
The Following 6 Users Say Thank You to markhaines1985 For This Useful Post: |
06-06-2017, 14:30 | #9 (permalink) |
Junior Member Join Date: Jun 2017 Location: Havana, Cuba
Member: 2724438 Status: Offline Thanks Meter: 0 | markhaines1985 Thanks for the post very good, worked to perfection Here is how you reset FRP on G930AZ 1. Put phone into download mode: 2. Then open custom odin. DO NOT use regualar odin. (Download here) 3. Select AP tab and select and flash Eng root file (Download here) 4. When phone comes back on wait for ADB drivers to install. 5. The run this .bat file (Download here) 6. If everything went right phone should automatically go back into download mode. 7. When back in download mode flash stock boot image. (Download Here) FRP REMOVED!!!! |
