03-28-2017, 11:13 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Ordu TÜRKİYE
Member: 1918391 Status: Offline Thanks Meter: 73 | G930F frp updated android 7 bootloader exception after frp reset this fw. G930FXXU1DQBO_G930FOJV1DQB7 updated with this fw. downgraded back to G930FXXU1BPJE_OJV1BPH4 but no wipe (selected home csc) after downgrade "type your pasword" on screen again wipedata factory reset using recovery menu. i stuck here G930FXXU1BPJE_OJV1BPH4 frp locked and simlocked. |
The Following User Says Thank You to gencom For This Useful Post: |
03-29-2017, 10:30 | #2 (permalink) |
Member: 1918391 Status: Offline Thanks Meter: 73 | problem resloved terminal commands add contact(open card manager redirecting samsung apps) samsung apps and install es file explorer install 3 apkfile from otg. downgrade google account manager because not work frp bypass apclication. apus launcher for easy operations. 1. install es file explorer from samsung apps 2. install gam6 apk from otg or sd card 3. install frp bypass aplication apk from otg or sd card 4. install apus launcher apk from otg or sd card login a gmail account with frp bypass. effected rom G930FXXU1BPJE_OJV1BPH4 downgrade possible from android 7 but maybe not required. http://forum.gsmhosting.com/vbb/f777...vices-2124806/ |
03-29-2017, 12:08 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | Thx for this info... If u like to scrach l3ft ear with right hand. Downgrade to 6.0.1 remove frp by favorite methode (not the box) then if you like update back to 7 |
The Following User Says Thank You to maremestera For This Useful Post: |
03-29-2017, 15:19 | #6 (permalink) |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | 100% possible i have done many..downgrade by full flash(4 files) then frp remove(use realterm +google account manger web login) |
The Following User Says Thank You to GSMsurgeon For This Useful Post: |
