03-27-2017, 15:47 | #1 (permalink) |
Freak Poster Join Date: May 2011 Location: United Kingdom
Member: 1574069 Status: Offline Thanks Meter: 32 | G930F/G935F FRP after Repair Network What is the solution for this situation? |
03-27-2017, 23:50 | #4 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2454163 Status: Offline Thanks Meter: 7 | Im not sure if this is similar issue but I had G935f (G935FXXU1APD1) imei patched and it does update itself couple of days after even "auto update" is off. Then when phone restarts it get dm verity verification failed and wont boot. I installed G935FXXU1BPHC released 16 Aug 2016. and seems fine now after couple of weeks after patching and repair network. I always wanted to install the oldest firmware if possible but this is the only way i fixed mine. |
03-30-2017, 00:02 | #12 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Treasure Island of the pacific
Member: 168090 Status: Offline Thanks Meter: 92 | Your problem is because you are using a custom recovery which is when the customer puts google account it will give you a block by frp message due to kernel being custom too. Solution 1. Flash the phone to a stock firmware like maybe the lowest 6.0.1 version you can find, then root with chainfire's auto-root, repair network then after that remove root, be sure select yes when it ask you to re-install stock boot image and your problem will be solve. Solution 2. Root the phone, write a good cert then flash back the stock firmware. br -blu |
