10-04-2016, 18:17 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | G930f RPMB PROVISIONED ! ASV TBL VER = 8 ASV TBL VER2 = 0 RPMB PROVISIONED how to solve it ? |
The Following User Says Thank You to jawad8305 For This Useful Post: |
10-04-2016, 22:12 | #3 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | tryed both combination boot files,we need need boot file with version G930FXXU1BP.. |
10-04-2016, 22:40 | #5 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | i dont think so as i mentioned before ,they released new firmware which closed the new method hole,we need new combination_boot version starting with G930FXXU1BP... anyway to get phone alive use some G930FXXU1BP... firmware |
10-05-2016, 12:08 | #7 (permalink) |
Freak Poster Join Date: Jan 2016 Age: 34
Member: 2516015 Status: Offline Thanks Meter: 100 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G930F Software version: 26.9 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM111 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G930F Android version: 6.0.1 Product code: SM-G930FZDATTT Phone version: G930FXXU1APB4 PDA version: G930FXXU1APB4 CSC version: G930FUUB1APB4 CSC country code: TRINIDAD AND TOBAGO CSC sales code: TTT HW version: MP 0.700 Phone SN: R58H30PLVNZ Modem board: SHANNON335 RF cal date: 20160305 IMEI: Checking Super user right... true Erasing FRP... OK Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.26.9 |
The Following User Says Thank You to DZcondor For This Useful Post: |
10-05-2016, 13:15 | #9 (permalink) |
No Life Poster Join Date: Jan 2005 Location: at work
Member: 112112 Status: Offline Sonork: 100.1621373 Thanks Meter: 238 | same probleme i have flashed COMBINATION_G930FXXU1APB4_boot,frp done but phone stuck at logo: ASV TBL VER = 8 ASV TBL VER2 = 0 RPMB PROVISIONED the phone not conected to pc pls any help |
The Following User Says Thank You to zeroualot_7 For This Useful Post: |
10-05-2016, 13:17 | #10 (permalink) | |
Member: 2516015 Status: Offline Thanks Meter: 100 | Quote:
10-05-2016, 15:13 | #13 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | to get phone alive flash version G930FXXU1BPH6 if you have new version G930FXXU1B... no solution will work for the moment they released new firmware which closed the new method hole,we need new combination_boot version starting with G930FXXU1B... |
10-05-2016, 15:37 | #15 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | i have phone with G930FXXU1BPH6 firmware and new method not work |
