02-07-2018, 04:31 | #1 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Los Angeles California
Member: 1549521 Status: Offline Thanks Meter: 19 | G930T unlock fail error (4) Help To unlock: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) To reset Pattern lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G930T Selected port: COM804 SAMSUNG Mobile USB Serial Port Software version: 30.7 Checking Login and Password... OK Ballance: 85 crd. You have 85 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G930T Android version: 7.0 Product code: Not Active Phone version: G930TUVS4BQJ2 PDA version: G930TUVS4BQJ2 CSC version: G930TTMB4BQJ2 CSC country code: USA CSC sales code: TMB HW version: MSM8996.00 Phone SN: R28H50STA4A Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-11-01 RF cal date: 2016.05.11 IMEI: 359755070040429 Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM5 detected Reading data from phone... OK Calculating... error (4) Done with Samsung Tool PRO v.30.7 Help |
