10-16-2017, 18:47 | #10 (permalink) |
No Life Poster Join Date: Feb 2003 Location: here
Member: 20953 Status: Offline Thanks Meter: 94 | I tried repair imei and patch cert for the same phone model on android 7... at some point it works but then I get a popup on the phone screen saying the sim count has changed and phone needs to restart, once it restarts I lose the network again and the phone thinks it's dual sim... I tried the Z3X set sim count but when phone reboots the imei is gone then I restart phone and the imei is back but it's NG then I do patch cert again and the phone starts with that same popup saying sim mode changed phone needs to reboot.... and so on! |
10-16-2017, 19:37 | #11 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
10-20-2017, 06:36 | #13 (permalink) |
Crazy Poster Join Date: Apr 2016
Member: 2559969 Status: Offline Thanks Meter: 12 | I flashed superman rom, used g930fd to write second IMEI, then repaired network and it works fine with dual sim. Plz thanks if the helped Sent from my SM-G930W8 using Tapatalk |
10-20-2017, 15:01 | #14 (permalink) |
Member: 2559969 Status: Offline Thanks Meter: 12 | If you use a custom kernel based off g930f it should work I believe. Have not tested it yet with g930w8 firmware, only g930f firmware but I think it should also work, maybe I'll assemble a twrp flashable file for building a IMEI repairable g930w8. Thanks if you think this would help. Sent from my SM-G930W8 using Tapatalk |
The Following User Says Thank You to WOWstin For This Useful Post: |
11-28-2017, 09:43 | #15 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | here is the latest version of Combination modem ( G930W8 ) https://mega.nz/#!TlIDkDTR!N3Do0hgBc...9VCsb74Myligw8 Flash it by placing it on CP section of ODIN .. & than Direct Unlock by Z3x ... |
