Old 06-09-2017, 08:57   #16 (permalink)
Member: 1967512
Sonork: 100.1675730
Thanks Meter: 10
BIG THNXS *** Bless You
but this is the riskly and hardwork
Old 06-09-2017, 09:08   #17 (permalink)
wong edan's Avatar
Member: 775581
Thanks Meter: 186
Anyone tested ?
Is it safe ?
Old 06-20-2017, 03:31   #18 (permalink)
Member: 2494408
Thanks Meter: 110
Downgrade modem for unlock done, thanks
Sent from my iPhone using Tapatalk
Old 06-25-2017, 12:30   #19 (permalink)
Member: 259188
Thanks Meter: 79
100% done...................
Old 06-28-2017, 14:23   #20 (permalink)
Member: 1234013
Thanks Meter: 3
Originally Posted by ordyan View Post
Just root and repair.
6.0.1 and 7.0 same, no changes in modem
Отправлено с моего iPhone используя Tapatalk
I'm running android 6.0.1 in g935f .
if I flash 7.0 and then repair ,will I still get signals ?
or I have to flash old modem and then run the setup ?
thanks
Old 06-28-2017, 17:33   #21 (permalink)
Member: 1234013
Thanks Meter: 3
I done repair but no network and when I'm pressing patch certificate its saying android 7.0 not supporting ?
Old 07-18-2017, 16:57   #22 (permalink)
Member: 2241097
Thanks Meter: 17
Good unlock solution...working perfect
Old 07-22-2017, 12:19   #23 (permalink)
ecs_lk's Avatar
Member: 358337
Thanks Meter: 46
Originally Posted by faurionutz View Post
G935F Android 7.0 Nougat Unlock Done by reading codes without root using Z3X Box
Steps:
1. Enable USB Debugging
2. Flash 6.0.1 Modem file: CP_G935FXXU1BPJG
3. Perform Read Codes with Z3X Box
4. Flash back 7.0 Modem file: CP_G935FXXU1DPLT
this methed works for unlock........
But i didnt get signal for 3G networks...others ok...
i full flashed 7.0 also..
any help.............
The Following User Says Thank You to ecs_lk For This Useful Post:
Old 08-15-2017, 15:52   #24 (permalink)
Member: 309375
Thanks Meter: 15
It worked!! Thank you
Old 08-22-2017, 17:25   #25 (permalink)
Member: 1092417
Sonork: 100.1645946
Thanks Meter: 45
Steps:
Successfully Unlocked by read code by using your method w/o any problem. I request to all to apply this method for Nougat version. Thank you very much!
Old 08-23-2017, 09:06   #26 (permalink)
Registered User
Member: 632643
Thanks Meter: 74
Important Note:
after read codes DO NOT ENTER YET THE UNLOCK CODES!!!
Flash back Nougat modem then you can enter the readed UNLOCK CODES!!!
(to avoid speaker,mic etc issues)
The Following User Says Thank You to CuLo For This Useful Post:
Old 08-26-2017, 19:17   #27 (permalink)
Member: 2744195
Thanks Meter: 4
Thank you man it help me.
Old 08-26-2017, 21:49   #28 (permalink)
Member: 914220
Thanks Meter: 206
Talking
thanks
Steps:
i dont think is good idea you do this
read steps
is for 7.0
Old 08-30-2017, 11:59   #29 (permalink)
Member: 772805
Thanks Meter: 2
done bro thanks a lot. After the downgrade of modem i selected unlock old method it got done
Old 09-02-2017, 08:06   #30 (permalink)
Member: 2494408
Thanks Meter: 110
thanks pro for share
Page generated in 0.22778 seconds with 8 queries
