12-07-2016, 09:34 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: cox's bazar bangladesh
Member: 1453066 Status: Offline Thanks Meter: 75 | G935F CERT Patch ok but emergency call Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G935F Software version: 27.3 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDAXSG Phone version: G935FXXU1APD1 PDA version: G935FXXU1APD8 CSC version: G935FOJV1APD8 CSC country code: UAE CSC sales code: XSG HW version: MP 0.801 Phone SN: RF8H525TT0A Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160521 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON335 Calculating... Ok HWID: 7C AB 0A 79 F9 74 A3 E1 47 F2 4A 87 F5 5B C2 CE Repairing... Ok Writing NV data... Ok Rebooting phone... Ok Repair done Done with Samsung Tool PRO v.27.3 REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-G935F Software version: 27.3 Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDAXSG Phone version: G935FXXU1APD1 PDA version: G935FXXU1APD8 CSC version: G935FOJV1APD8 CSC country code: UAE CSC sales code: XSG HW version: MP 0.801 Phone SN: RF8H525TT0A Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160521 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.3 |
12-07-2016, 09:45 | #2 (permalink) |
No Life Poster Join Date: Apr 2016
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | can you see this update ? http://forum.gsmhosting.com/vbb/f475...t-frp-2164803/ try with latest software, should be work, |
12-12-2016, 10:13 | #3 (permalink) |
Freak Poster Join Date: Sep 2012 Location: south africa Age: 39
Member: 1813139 Status: Offline Thanks Meter: 45 | same here before i repair more then 15 phone but now i facing that problem after repair imei and patch cert still emrergency calls only /????? i try all verions |
