02-02-2017, 22:41 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: deveselu
Member: 543935 Status: Offline Thanks Meter: 59 | g935f dead by COMBINATION_FA60_G935F i have this message and not enter to donwload mode, also i tried with jtag Botloader exception [ RST_STAT = 0X10000000 ] EVT 1.0 ASV TBL VER = 8, Grade = C ASV TBL VER2 = 0 ECT : PARA005O LOT_ID = NAC1Z CHIP_ID = 02f44c5c3b5c CHIP_ID2 = 00000000 MNGS:37`C APOLLO:38`C G3D:38`C ISP:38`C Exception: do_handler_sync: DABT_EL1(esr: 0x96000010) pc : 0x8f013db4 ir : 0x8f013db4 sp : 0x8f113890 |
02-03-2017, 02:43 | #3 (permalink) |
Freak Poster Join Date: Nov 2014 Location: accra -ghana
Member: 2296236 Status: Offline Thanks Meter: 143 | Not dead let the battery drain and hold download mode keys then insert usb Sent from my iPhone using Tapatalk |
The Following User Says Thank You to georgeodoom For This Useful Post: |
02-03-2017, 12:09 | #4 (permalink) |
No Life Poster Join Date: Jan 2002
Member: 8379 Status: Offline Thanks Meter: 35 | I have the same problem. Turn phone off, Hold down + home + power, just keep holding for 30 sec or more, it will get into download mode. But my problem now is Flash the phone with stock firmware, but phone now boot up in Android recovery menu Any one can help ? |
02-03-2017, 13:25 | #5 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | Quote:
02-03-2017, 15:02 | #6 (permalink) |
Member: 8379 Status: Offline Thanks Meter: 35 | Thanks Jepetu When i try to repair with DRK it cannot find ADB How can i enable ADB now ? G930F_XXU1APGG_TEF1APG1 File analysis... Ok Total file size: 0x17737ADC (375 Mb) Searching USB Flash interface... COM12 detected Setup connection... Ok Set PIT file... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending param.bin... Ok Sending cm.bin... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending modem.bin... Ok Sending cache.img... Ok Sending hidden.img... Ok Flashing done (time - 00:00:34) Done with Samsung Tool PRO v.27.7 Operation: Repair DRK Selected model: SM-G930F Software version: 27.7 Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM12 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Sending data to phone... Ok Waiting ADB device... timeout Phone not found Done with Samsung Tool PRO v.27.7 |
