07-28-2016, 12:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: India
Member: 1152038 Status: Offline Thanks Meter: 257 | G935f Direct Unlock done in Z3X READ CODES: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read codes' to read security codes. DIRECT UNLOCK: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G935F Software version: 26.2 Searching Samsung modem... detected COM337 Reading phone info... OK Model: SM-G935F AP Version: G935FXXU1APF2 CSC Version: G935FOJV1APF1 CP Version: G935FXXU1APEQ Product code: SM-G935FZDAKSA Phone S/N: RF8H53XXXX Imei: 3599480784XXXXX Unique number: CE041604C9A6D30B03 Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.2 Thanks for z3x team.... |
The Following User Says Thank You to m_mustakeem For This Useful Post: |
