01-09-2017, 02:34 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | g935f frp unlock with z3x done To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 27.7 Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM67 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: PDA version: G935FXXU1BPH6 CSC version: G935FVFG1BPH1 CSC country code: Germany CSC sales code: VD2 HW version: Phone SN: RF8H32VT96N Chip name: EXYNOS8890 Modem board: RF cal date: IMEI: Checking Super user right... true Erasing FRP... Ok Restore original kernel? Yes Checking local file... not found Searching server... Ok Downloading file... Ok Checking local file... Ok Restoring kernel... Ok Rebooting phone... Ok Reset FRP done Done with Samsung Tool PRO v.27.7 |
01-17-2017, 19:02 | #2 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Moroni Comoros Age: 49
Member: 127093 Status: Offline Thanks Meter: 22 | FRP G935F SUCCES WITH Z3X UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 27.7 Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM10 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDABOG Phone version: G935FXXU1APEQ PDA version: G935FXXU1APF2 CSC version: G935FBOG1APF1 CSC country code: France CSC sales code: BOG HW version: MP 0.801 Phone SN: RF8H40D14KE Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160405 IMEI: Checking Super user right... true Erasing FRP... Ok Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Restoring kernel... Ok Rebooting phone... Ok Reset FRP done Done with Samsung Tool PRO v.27.7 |
The Following User Says Thank You to ibrahimbae For This Useful Post: |
