10-19-2019, 09:19 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Pakistan
Member: 682736 Status: Offline Thanks Meter: 457 | G935F Imei repair not working I Did repair imei but after reboot phone with old imei. can not change imei... Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 8.0.0 PDA version: G935FXXS5ESF1 CSC version: G935FOXE5ESF1 Phone version: G935FXXS5ESEB Product code: SM-G935FZBUKSA CSC country code: Russia CSC sales code: SER Phone SN: R58HC144GVK IMEI: 354737********* HW version: MP 0.801 RF cal date: 20161207 Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2019-06-01 Boot Warranty bit: 1 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Writing security... OK Rebooting phone... OK Done with Samsung Tool PRO v.38.2 |
10-19-2019, 09:51 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
Hello, try installing other firmware binary 5 for g935f from different countries from what you have on your phone and try to redo the patch and check if it gives the same error if you go to the z3x site at this link it tells you the binary firmware for g935f tested for the pacth I'll copy the result to you https://z3x-team.com/check-your-phone/ SAMSUNG TOOL PRO 38.2 AND SAMSUNG SM-G935F: **Patch Certificate using credits ****Tested firmwares: ****OTHER: G925IDVU3EPIF, G930FXXU2DRB6, G930KKKU1DPLP, G930KKKU2ESF1, G930LKLU2ARI1, G930W8VLU4ARH1, G935FXXS4ESB5, G935FXXS4ESBA, G935FXXS4ESBB, G935FXXS4ESBC, G935FXXS4ESBE, G935FXXS4ESC7, G935FXXS4ESDB, G935FXXS5ESDA, G935FXXS5ESDB, G935FXXS5ESDC, G935FXXS5ESDD, G935FXXS5ESDE, G935FXXS5ESEA, G935FXXS5ESEB, G935FXXS5ESEC, G935FXXS5ESED, G935FXXU1APB2, G935FXXU1APB3, G935FXXU1APB4, G935FXXU1APB6, G935FXXU1APB8, G935FXXU1APBB, G935FXXU1APBD, G935FXXU1APD1, G935FXXU1APD9, G935FXXU1APE9, G935FXXU1APEQ, G935FXXU1APF4, G935FXXU1APG1, G935FXXU1APGH, G935FXXU1APJ1, G935FXXU1BPH1, G935FXXU1BPHJ, G935FXXU1BPI6, G935FXXU1BPJE, G935FXXU1BPJG, G935FXXU1BPJJ, G935FXXU1BPK6, G935FXXU1BPL1, G935FXXU1BQA1, G935FXXU1CPJ2, G935FXXU1DPLT, G935FXXU1DQA3, G935FXXU1DQB1, G935FXXU1DQB3, G935FXXU1DQC2, G935FXXU1DQCF, G935FXXU1DQD7, G935FXXU1DQE7, G935FXXU1DQE8, G935FXXU1DQEN, G935FXXU1DQER, G935FXXU1DQF1, G935FXXU1DQF2, G935FXXU1DQFD, G935FXXU1DQG2, G935FXXU1DQH6, G935FXXU1DQHD, G935FXXU1DQIC, G935FXXU1DQIL, G935FXXU1DQJ1, G935FXXU1DQL7, G935FXXU1DQL8, G935FXXU1DRA5, G935FXXU1DRA6, G935FXXU2ARA1, G935FXXU2DRA7, G935FXXU2DRA9, G935FXXU2DRAC, G935FXXU2DRAE, G935FXXU2DRAG, G935FXXU2DRAH, G935FXXU2DRAR, G935FXXU2DRB6, G935FXXU2DRC7, G935FXXU2DRC8, G935FXXU2ERD5, G935FXXU2ERD6, G935FXXU2ERE8, G935FXXU2EREO, G935FXXU2ERG2, G935FXXU2ERGC, G935FXXU2ERH1, G935FXXU2ERH3, G935FXXU2ERH4, G935FXXU3ARI1, G935FXXU3ERHC, G935FXXU3ERI1, G935FXXU3ERI2, G935FXXU3ERIA, G935FXXU3ERJ7, G935FXXU3ERJ8, G935FXXU3ERJ9, G935FXXU3ERJA, G935FXXU3ERJC, G935FXXU3ERJE, G935FXXU3ERK3, G935FXXU3ERKF, G935FXXU3ERL3, G935FXXU3ESA1, G935FXXU3ESA3, G935FXXU4ASA1, G935FXXU4ESA5, G935FXXU4ESAE, G935FXXU4ESB1, G935FXXU4ESB2, G935FXXU4ESCD, G935FXXU5ASD1, G935FXXU5ESD2, G935KKKU2ERI1, G935KKKU2ESA1, G935KKKU2ESD1, G935LKLU1APC3, G935LKLU1APJ9, G935LKLU1DQJ1, G935LKLU1ERG2, G935LKLU2ARI1, G935LKLU2ERI1, G935LKLU2ESA1, G935LKLU2ESD1, G935LKLU2ESF1, G935SKSU1APB2, G935SKSU1DPLP, G935SKSU1DQF3, G935SKSU1DQJ1, G935SKSU1DQK1, G935SKSU1ERG2, G935SKSU2ERI1, G935SKSU2ESA1, G935SKSU2ESD1, G935SKSU2ESF1, G935W8VLS3BRA2, G935W8VLS3BRC2, G935W8VLS3CRG2, G935W8VLS5CRJ1, G935W8VLS5CSA1, G935W8VLS6CSC1, G935W8VLU2BQK4, G935W8VLU3ARA1, G935W8VLU5ARI1, G935W8VLU6CSB2, G935W8VLU6CSE1 Or try installing the modem combination u5 for g935f and patch it with z3x, if this solution is not successful you should use other boxes if you have to do the pacth cert G935FXXU5ASD2_ENG_modem U5 Download https://boxwares.net/82c4a7dbb23c9a9...xWares.tar.md5 Last edited by amleto90; 10-19-2019 at 09:58. | |
The Following User Says Thank You to amleto90 For This Useful Post: |
