12-06-2016, 16:48 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: italy
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | G935F imei successfully repaired, and running line L 100% REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-G935F Software version: 27.4 Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZKAWIN Phone version: G935FXXU1APEQ PDA version: G935FXXU1APF2 CSC version: G935FWIN1APE1 CSC country code: ITALY CSC sales code: WIN HW version: MP 0.801 Phone SN: RF8H306RNPE Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160225 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.4 |
12-06-2016, 17:05 | #2 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G935F Software version: 27.4 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: G935FXXU1APB6 PDA version: G935FXXU1APB6 CSC version: G935FOJV1APB4 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: RQ8H50ASQRY Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (decompress error) Done with Samsung Tool PRO v.27.4 |
12-06-2016, 18:57 | #3 (permalink) | |
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | Another g935f successfully repaired Quote:
The Following User Says Thank You to salvo1278 For This Useful Post: |
12-06-2016, 19:47 | #4 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Can help me do modem version dowgrade? REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G935F Software version: 27.4 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: PDA version: G935FXXU1APB6 CSC version: G935FOJV1APB4 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: RF8H20FL7BN Chip name: EXYNOS8890 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... error (0) error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.4 |
12-07-2016, 10:56 | #7 (permalink) |
Member: 1027748 Status: Offline Sonork: 609321045 Thanks Meter: 252 | try to download firmware downgrade of June G935FXXU1APF2 CSC version: G935FWIN1APE1 CSC country code: ITALY CSC sales code: WIN |
12-08-2016, 06:53 | #8 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 239158 Status: Offline Sonork: 100.1602571 Thanks Meter: 38 | not network Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDLTPA Phone version: G935FXXU1APB4 PDA version: G935FXXU1APB4 CSC version: G935FUUB1APB4 CSC country code: PANAMA CSC sales code: TPA HW version: MP 0.801 Phone SN: R58H744X2TR Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160726 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON335 Calculating... Ok HWID: FD 8E 21 83 CB 04 44 7C EB C3 16 A4 2F 0B 66 8B Repairing... Ok Writing NV data... Ok Rebooting phone... Ok Repair done Done with Samsung Tool PRO v.27.4 |
The Following User Says Thank You to welfreng For This Useful Post: |
12-08-2016, 14:29 | #9 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: africa
Member: 586192 Status: Offline Thanks Meter: 66 | Quote:
Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDAXFV Phone version: G935FXXU1BPHJ PDA version: G935FXXS1BPI8 CSC version: G935FVFG1BPH1 CSC country code: South Africa CSC sales code: XFV HW version: MP 0.801 Phone SN: R58HA059RTH Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20161001 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.4.2 same no network | |
12-08-2016, 17:32 | #10 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | I can not repair the G935f imei can help, I noticed that in the configurations the model G935fd is being that it is G935f how to repair? REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G935F Software version: 27.4.2 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: G935FXXU1APB6 PDA version: G935FXXU1APB6 CSC version: G935FOJV1APB4 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: 00000000000 Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.4.2 |
12-26-2016, 15:01 | #12 (permalink) |
No Life Poster Join Date: Jul 2008 Location: UK
Member: 819396 Status: Offline Thanks Meter: 113 | ive tried the above instruction and used patch certificate after repair imei and now also no network. has anyone managed to solve this? Operation: Patch Certificate Selected model: SM-G935F Software version: 27.6 Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDATTR Phone version: G935FXXU1APB2 PDA version: G935FXXS1APG2 CSC version: G935FBTU1APB2 CSC country code: AUSTRIA CSC sales code: TTR HW version: MP 0.801 Phone SN: RF8H21WYQWD Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160223 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.6 |
