12-04-2016, 08:29 | #31 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Hungary Age: 40
Member: 22869 Status: Offline Thanks Meter: 132 | Operation: Patch Certificate Selected model: SM-G935F Software version: 27.3 Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZDATHL Phone version: G935FXXU1APB6 PDA version: G935FXXU1APB6 CSC version: G935FOLB1APB6 CSC country code: THAILAND CSC sales code: THL HW version: MP 0.801 Phone SN: RF8H3xxxxxL Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160331 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.3 Error: Not registered on network. *#06# and *#0011# empty |
12-05-2016, 14:19 | #33 (permalink) | |
Freak Poster Join Date: May 2008 Location: SYRIA Age: 32
Member: 772728 Status: Offline Thanks Meter: 163 | nv Quote:
write nv file link https://mega.nz/#!sBknyRBY for key check in your box ? good luck my frind | |
The Following User Says Thank You to ahmad0x9 For This Useful Post: |
12-05-2016, 20:10 | #34 (permalink) |
Insane Poster Join Date: Dec 2013
Member: 2091899 Status: Offline Thanks Meter: 18 | Here is...G935f network solution after patch cert no netowrk First..flash firmware of feb..march or april patch..... Then root your phone via z3xxx.(important please use root method only z3x) Then repair imei nd patch cert After patch cert Do Reset frp/rec/rcc lock Cz patch cert need custom kernel... Enjoyyyyy my tested solution |
12-05-2016, 20:14 | #35 (permalink) |
Insane Poster Join Date: Sep 2013 Location: chile
Member: 2022858 Status: Offline Thanks Meter: 7 | Solution Install correct rom Install twrp Install custom kernel Hard reset Install super su Repair imei Patch cert No need frp z3x Work 100% signal Work 100% wifi No lag After hard reset lost signal |
The Following User Says Thank You to anacondis For This Useful Post: |
12-05-2016, 23:15 | #39 (permalink) |
Member: 2022858 Status: Offline Thanks Meter: 7 | or wifi password lost and kernel lag problem solution use Build.prop Editor Tweaker_1.3.2 edit ro.secure.support true change to false ro.sf.lcd_density 480 change to 640 |
12-06-2016, 12:58 | #44 (permalink) | |
Insane Poster Join Date: Aug 2014
Member: 2240278 Status: Offline Sonork: leide Thanks Meter: 3 | Quote:
