11-16-2016, 17:10 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Bulgaria Age: 53
Member: 3658 Status: Offline Thanks Meter: 66 | G935F problem remove FRP G935FXXS1BPI8 firmware But if you have G935FXXS1BP... what the procedure . If i choise RESET FRP/React/EE , after write new sboot phone start and still only LOGO. ADB mode not active . After write again full flash XXS1BS.. al is ok . Try to write combination files .After write remove frp OK , factory reset ok but after flash firmware ask again google account. Please explain what is the procedurte remove FRP for new firmware. Thanks advance! |
11-16-2016, 21:03 | #2 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro try to downgrade firmware to old one without modem if u get sw rev protection and try frp reset again it should work Sent from my SM-G935F using Tapatalk |
11-17-2016, 07:53 | #3 (permalink) |
Member: 3658 Status: Offline Thanks Meter: 66 | not work bro ... downgrade without modem . Phone still to Logo .reset FRP with ADB . But after re write new firmware to work phone again ask google again . |
11-17-2016, 08:23 | #5 (permalink) | |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | Quote:
1.Download and installRealTerm program 2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device. 3.Start phone and connect to WIFI also plug into the computer with your usb cable. 4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX 5.Right click on my computer and select manage once it opens click device manager then modems 6.Under modems you should see a Samsung device. right click it then select properties 7.Once the properties window opens select modem tab and see what port it is on like com5 for an example 8.Now that you know the com port number close all device manager windows and open RealTerm again 9.Under the ports tab in RealTerm enter your port number then click change. 10.Next, click the send tab. you will need to send these two commands with the Send ASCII button 11.First at+creg?\r\n 12.Then atd1234;\r\n 13.Look at your phone and the dailer will pop up 14.click on massege then write Google in sms | |
11-17-2016, 11:01 | #7 (permalink) |
Member: 3658 Status: Offline Thanks Meter: 66 | Thanks ! When i came to install copy com.rootjunky.frpbypass-1.0.apk all is ok but Unfortunately, FRP Bypass has stopped. Istall ok nut when i run say this message |
11-17-2016, 14:39 | #9 (permalink) |
No Life Poster Join Date: Apr 2005 Location: brunei
Member: 141262 Status: Offline Thanks Meter: 348 | use need to install this Android_6_Google_Account_Manager.apk bro before install com.rootjunky.frpbypass-1.0.apk.. it should be 100% working because your version is marshmallow already thats why Unfortunately, FRP Bypass has stopped.. |
The Following User Says Thank You to watari31 For This Useful Post: |
11-18-2016, 05:54 | #11 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | WOW...this is a perfect example of using a butter knife instead of a screwdriver lol lol Why dont you just flash the eng boot, not eng sboot, so adb is enabled then bypass frp. |
11-21-2016, 15:17 | #15 (permalink) |
Freak Poster Join Date: May 2009 Location: google
Member: 1029926 Status: Offline Sonork: Tufail4463 Thanks Meter: 17 | Use This Method Your Problem Will Solve I Have Done G930f & G935f http://forum.gsmhosting.com/vbb/f453...f-frp-2156268/ |
