02-10-2017, 16:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Afrique du sud Age: 42
Member: 430612 Status: Offline Thanks Meter: 301 | g935f security damage Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G935F Software version: 27.7 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: G935FXXU1APBB PDA version: G935FXXU1APB9 CSC version: G935FTEF1APB5 CSC country code: Germany CSC sales code: VIA HW version: Phone SN: RF8H42F2GTY Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.7 plz help me to repair security for this phone |
02-15-2017, 22:17 | #3 (permalink) |
Major Poster Join Date: Apr 2014
Member: 2161268 Status: Offline Thanks Meter: 0 | [ 15.02.2017 22:07:00 ] Waiting ADB device... Ok [ 15.02.2017 22:07:00 ] Reading phone info... [ 15.02.2017 22:07:00 ] Model: SM-G935F [ 15.02.2017 22:07:00 ] Android version: 6.0.1 [ 15.02.2017 22:07:00 ] Product code: [ 15.02.2017 22:07:00 ] Phone version: G935FXXU1APB4 [ 15.02.2017 22:07:00 ] PDA version: G935FXXU1APC8 [ 15.02.2017 22:07:00 ] CSC version: G935FBTU1APB2 [ 15.02.2017 22:07:00 ] CSC country code: UK & IRE [ 15.02.2017 22:07:00 ] CSC sales code: BTU [ 15.02.2017 22:07:00 ] HW version: [ 15.02.2017 22:07:00 ] Phone SN: RF8H3307HCT [ 15.02.2017 22:07:00 ] Chip name: EXYNOS8890 [ 15.02.2017 22:07:00 ] Modem board: SHANNON335 [ 15.02.2017 22:07:00 ] RF cal date: [ 15.02.2017 22:07:00 ] IMEI: [ 15.02.2017 22:07:00 ] Checking Super user right... true [ 15.02.2017 22:08:00 ] Reading NV data... Ok [ 15.02.2017 22:10:00 ] Checking NV data... error [ 15.02.2017 22:10:00 ] Security damaged (1) I tried a nv backup from a working phone and many more things... Is there a solution for this, I found many threads with the same topic, but also no solution... |
02-17-2017, 09:53 | #4 (permalink) |
Freak Poster Join Date: May 2013
Member: 1943302 Status: Offline Thanks Meter: 5 | Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: Phone version: PDA version: G935FXXU1APD8 CSC version: G935FOJV1APD8 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: Chip name: EXYNOS8890 Modem board: RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.7 ANY SOLUTION |
02-18-2017, 13:47 | #8 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Inside Samsung Pocket Age: 40
Member: 489331 Status: Offline Thanks Meter: 1,141 | Repaired many phones with security damage 1 and solution tested and 100% work Nv data from another same phone not help and combination also not help don't waiste time. |
02-18-2017, 14:01 | #10 (permalink) |
Freak Poster Join Date: Dec 2010 Location: pakistan Age: 37
Member: 1477840 Status: Offline Sonork: 100.1612459 Thanks Meter: 37 | write this modem https://www.androidfilehost.com/?fid=24580943222146650 after write modem write nv data then repair imei option prob solved |
The Following User Says Thank You to mr786 For This Useful Post: |
02-22-2017, 13:28 | #11 (permalink) | |
Member: 430612 Status: Offline Thanks Meter: 301 | Quote:
thanks also face same problem with g930f need help | |
