07-12-2016, 16:37 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Pakistan Peshawar Age: 34
Member: 242264 Status: Offline Sonork: 100.1582011 Thanks Meter: 33 | G935fd boot loop |
07-14-2016, 09:53 | #10 (permalink) |
Member: 242264 Status: Offline Sonork: 100.1582011 Thanks Meter: 33 | i am flashing it with the same firmware which came in phone and i will try drk repair i will let you know but before this when i flash the phone and repair drk it is stuck on red screen and bootloop |
07-14-2016, 09:56 | #11 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
note combinate file not 4 file | |
07-14-2016, 16:20 | #13 (permalink) |
Member: 242264 Status: Offline Sonork: 100.1582011 Thanks Meter: 33 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair DRK Selected model: SM-G935F Software version: 25.9 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM146 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Android version: 6.0.1 Boot version: G935FXXU1APB8 Platform: exynos7420 Boot serial: ce041604c8976f1f04 Product board: herolte Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Checking DRK status... OK Repairing DMVT key... error Rebooting phone... OK Repair DRK done Done with Samsung Tool PRO v.25.9 |
