11-30-2016, 18:23 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Dubai
Member: 1334781 Status: Offline Sonork: 0010 Thanks Meter: 80 | G935S imei 000000000000000 please help me info Operation: Info Selected model: SM-G935S Software version: 27.2 Searching Samsung modem... detected COM113 Reading phone info... Ok Model: SM-G935S AP version: G935SKSU1APF5 CSC version: G935SSKC1APF5 CP version: G935SKSU1APF1 Product code: SKC Phone SN: ce05160593295c0404 Unique number: CE05160593295C0404 Reading IMEI... Ok IMEI: 000000000000000 (SIGN: NG_NONE) Done with Samsung Tool PRO v.27.2 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G935S Android version: 6.0.1 Product code: Phone version: G935SKSU1APF1 PDA version: G935SKSU1APF5 CSC version: G935SSKC1APF5 CSC country code: KOREA CSC sales code: SKC HW version: Phone SN: Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.2 help my how repair............... |
12-17-2016, 13:14 | #3 (permalink) |
Member: 1334781 Status: Offline Sonork: 0010 Thanks Meter: 80 | it is impossible to restore it dosing errors,,,, REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Repair Selected model: SM-G935S Software version: 27.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G935S Android version: 6.0.1 Product code: Phone version: G935SKSU1APF1 PDA version: G935SKSU1APF5 CSC version: G935SSKC1APF5 CSC country code: KOREA CSC sales code: SKC HW version: Phone SN: 00000000000 Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.5 |
12-19-2016, 10:46 | #4 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
