02-10-2018, 17:44 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1038150 Status: Offline Thanks Meter: 45 | g935v read codes server done and secret code *#06# *#1234# *#7465625# problem [ 10.02.2018 18:46:00 ] Selected model: SM-G935V [ 10.02.2018 18:46:00 ] Selected port: COM9 USB Serial Port [ 10.02.2018 18:46:00 ] Software version: 30.7 [ 10.02.2018 18:46:00 ] [ 10.02.2018 18:46:00 ] Checking Login and Password... OK [ 10.02.2018 18:46:00 ] Ballance: 50 crd. [ 10.02.2018 18:47:00 ] You have 50 credit(s) left. This operation takes 5 credits.Continue? Yes [ 10.02.2018 18:47:00 ] Waiting ADB device... OK [ 10.02.2018 18:47:00 ] Reading phone info... [ 10.02.2018 18:47:00 ] Model: SM-G935V [ 10.02.2018 18:47:00 ] Android version: 7.0 [ 10.02.2018 18:47:00 ] Product code: Not Active [ 10.02.2018 18:47:00 ] Phone version: G935VVRU4BQK4 [ 10.02.2018 18:47:00 ] PDA version: G935VVRU4BQK4 [ 10.02.2018 18:47:00 ] CSC version: G935VVZW4BQK4 [ 10.02.2018 18:47:00 ] CSC country code: USA [ 10.02.2018 18:47:00 ] CSC sales code: VZW [ 10.02.2018 18:47:00 ] HW version: REV0.7 [ 10.02.2018 18:47:00 ] Phone SN: 00000000000 [ 10.02.2018 18:47:00 ] Chip name: MSM8996 [ 10.02.2018 18:47:00 ] Modem board: MSM8996 [ 10.02.2018 18:47:00 ] Security patch: 2017-12-01 [ 10.02.2018 18:47:00 ] RF cal date: 2016.03.25 [ 10.02.2018 18:47:00 ] IMEI: 35************3 [ 10.02.2018 18:47:00 ] Waiting for device to become ready... OK [ 10.02.2018 18:47:00 ] Initialization zTool... OK [ 10.02.2018 18:47:00 ] Running zTool, please wait... [ 10.02.2018 18:47:00 ] Start... OK [ 10.02.2018 18:47:00 ] Initialization... OK [ 10.02.2018 18:48:00 ] Generate and check client proof... OK [ 10.02.2018 18:48:00 ] Verify proof by client... OK [ 10.02.2018 18:48:00 ] Reading data from phone... OK [ 10.02.2018 18:48:00 ] Searching Ramdump interface... COM86 detected [ 10.02.2018 18:48:00 ] Reading data from phone... OK [ 10.02.2018 18:48:00 ] Calculating... OK [ 10.02.2018 18:48:00 ] Searching server... OK [ 10.02.2018 18:48:00 ] Waiting for server answer... OK [ 10.02.2018 18:49:00 ] Freeze code: 00000000 [ 10.02.2018 18:49:00 ] NET lock: 01234567 [ 10.02.2018 18:49:00 ] SUB lock: 01234567 [ 10.02.2018 18:49:00 ] SP lock: 01234567 [ 10.02.2018 18:49:00 ] CP lock: 01234567 [ 10.02.2018 18:49:00 ] For check lock status: |
The Following User Says Thank You to blackie06 For This Useful Post: |
02-10-2018, 18:43 | #4 (permalink) |
No Life Poster Join Date: Feb 2015 Location: Jamaican
Member: 2339843 Status: Offline Thanks Meter: 1,450 | Lol...seems a newbie to the phone world..bro almost all verizon devices come unlocked,unless device firmware was changed to another..do research before mking attemp to unlock a device...switch device to gsm or global |
The Following User Says Thank You to ziggywong0305 For This Useful Post: |
02-11-2018, 00:14 | #6 (permalink) |
No Life Poster Join Date: Jan 2018
Member: 2802156 Status: Offline Thanks Meter: 173 | LMFAO, almost spill my beer when I read this thread, you guys hahahahaha NET lock: 01234567 Literally me reading this thread right now: https://hooktube.com/watch?v=KHZ8ek-6ccc and https://hooktube.com/watch?v=zdPL4W8LXgY Flash g935U or g935T firmware for your build rev here you go: https://updato.com/firmware-archive-...A1FA163EE8F90B Verizon LTE postpaid come unlock out the box, EXCEPT for Total Wireless/Xfinity (verizon MVNO or prepaid) For CCT - Xfinity you DO NEED TO READ CODE, in future always check with another carrier sim FIRST to see if device REQUEST CODE. Last edited by gsm_service4u; 02-11-2018 at 00:23. |
The Following User Says Thank You to gsm_service4u For This Useful Post: |
02-11-2018, 00:19 | #7 (permalink) |
Member: 2802156 Status: Offline Thanks Meter: 173 | Check IMEI if blacklisted, check sim, dial *#0011# after flashing another firmware (VZW disables dialer codes) and make sure MIPI PASS Bro I see you are not new on this forum, almost A DECADE OF MEMBERSHIP! Were you high or something?? lol |
02-11-2018, 01:13 | #8 (permalink) |
Insane Poster Join Date: Mar 2013 Location: nigeria
Member: 1903487 Status: Offline Sonork: 100.1654467 Thanks Meter: 8 | It good to check thread on this forum before embarking on risk you are not sure of. You just waste some cash but experience money can’t buy is gained Sent from my iPhone using Tapatalk Pro |
The Following User Says Thank You to layita For This Useful Post: |
02-12-2018, 18:36 | #12 (permalink) | |
Member: 2802156 Status: Offline Thanks Meter: 173 | Quote: The way to fix is to flash combination and resync efs, that sometimes fixes it but usually only if the device is reporting NON-FATAL MIPI ERROR, I've had one g950u that said TUNER MIPI FAIL and that one couldn't be fixed with the efs resync method, but yours might be able to. To resync efs it's a dialer code in combination..*#33725327#, if done correctly you will NOT LOSE IMEI BUT BE VERY CAREFUL- DO NOT ERASE EFS Can anyone say what is up with these phones suddenly getting MIPI fail out of nowhere?? | |
02-12-2018, 20:33 | #13 (permalink) |
Banned Join Date: Jan 2014 Location: Havana, Cuba Age: 40
Member: 2107306 Status: Offline Thanks Meter: 612 | MIPI is extra layer of protection enabled by samsung to verify hardware in this case the charge connector, which handle USB/UART over same connector. They force disable network on hardware level exactly same as for IMEICERT fail on MIPI fail on new devices. Some of qcom samsung can be solved with erase backup & restore backup option via ##33725327# need combination firmware or bypass knox with gcpro. Careful do not erase efs its not going to fix MIPI it will fail IMEICERT if any one do so. |
The Following 2 Users Say Thank You to Prsctt For This Useful Post: |
02-12-2018, 21:20 | #14 (permalink) | |
For example I have an s7 that has burnt out charge port - no charge or data working on it, so can only charge with wireless Qi pad, however service still works and MIPI pass. Other users have stated that FATAL MIPI Fail can be fixed by replacing a chip, the FEMid IC on the board, I guess it's responsible for tuning the antenna or establishing some part of the baseband's communications to the antenna and when it goes bad this error occurs. Go search on xda and on this forum in different sections - MIPI FAIL and you will see the various discussions going on about how to resolve this problem. | |
