11-30-2016, 20:32 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: CANADA
Member: 292789 Status: Offline Thanks Meter: 636 | G935w8 Incorrect IMEI signature Samsung Tool PRO v.27.3 BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. (Note, that the cert file for this model is unique. You can write cert, wich is readed from this device exactly.) Operation: Write CERT Selected model: SM-G935W8 Software version: 27.3 Waiting ADB device... Ok Reading phone info... Model: SM-G935W8 Android version: 6.0.1 Product code: SM-G935WZKARWC Phone version: G935W8VLU1APD3 PDA version: G935W8VLU1APD3 CSC version: G935W8OYA1APD3 CSC country code: Canada CSC sales code: RWC HW version: REV0.1 Phone SN: RF8H52VA3GM Chip name: EXYNOS8890 Modem board: SHANNON335 RF cal date: 20160526 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON335 Calculating... Ok HWID: FD 1A 34 3E 65 56 DD 77 C1 CA DD E1 BF 4B D5 CC Initialization AT RIL... AT RIL stopped, restarting... Ok Checking for compatible phone and cert Phone KEY ID: 0445 Checking certificate file... error Incorrect IMEI signature Done with Samsung Tool PRO v.27.3 |
The Following User Says Thank You to ansari123 For This Useful Post: |
11-30-2016, 20:57 | #4 (permalink) |
Member: 292789 Status: Offline Thanks Meter: 636 | Operation: Info Selected model: SM-G935W8 Software version: 27.3 Searching Samsung modem... detected COM211 Reading phone info... Ok Model: SM-G935W8 AP version: G935W8VLU1APD3 CSC version: G935W8OYA1APD3 CP version: G935W8VLU1APD3 Product code: SM-G935WZKARWC Phone SN: RF8H52VA3GM Unique number: 9886743649324E4C35 Reading IMEI... Ok IMEI: 3561600*****155 (SIGN: NG_SIGN) Done with Samsung Tool PRO v.27.3 |
12-07-2016, 08:55 | #8 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | |
12-07-2016, 19:10 | #9 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Canada
Member: 1381685 Status: Offline Sonork: 100.1668719 Thanks Meter: 81 | |
09-15-2018, 11:49 | #10 (permalink) |
Crazy Poster Join Date: Nov 2015 Location: Chittagong
Member: 2491964 Status: Offline Sonork: 100.1672132 Thanks Meter: 21 | Operation: Write CERT Selected model: SM-J710F Software version: 33.8 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 6.0.1 PDA version: J710FXXU3AQD1 CSC version: J710FOJV3AQD1 Phone version: J710FXXU3AQD3 Product code: SM-J710FZDDXSG CSC country code: UAE CSC sales code: XSG Phone SN: RF8H92QW9TY IMEI: 357412075345286 HW version: MP 0.300 RF cal date: 20160924 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2017-04-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 8F 00 00 00 00 00 00 00 00 00 00 00 32 2D 86 B5 Calculating... OK Initialization AT RIL... AT RIL stopped, restarting... OK Checking for compatible phone and cert Phone KEY ID: 0740 Checking certificate file... error Incorrect IMEI signature Done with Samsung Tool PRO v.33.8 pls Solve |
The Following User Says Thank You to nrekram For This Useful Post: |
