09-02-2019, 12:20 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: india
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | g950u (s8 sprint 9.0 ver) unlock help need new security Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Unlocking TMB using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock TMB via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Unlocking SPR using sever: 1. Insert not SPR card to the phone and power it on. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock...' button, select 'Unlock SPR via Server', write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G950U Selected port: COM1 Communications Port Software version: 37.0 Checking Login and Password... OK Ballance: 31 crd. You have 31 credit(s) left. This operation takes 8 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950U Android version: 9 PDA version: G950USQU5DSD3 CSC version: G950UOYN5DSD3 Phone version: G950USQU5DSD3 Product code: SM2G950UZKASPR CSC country code: USA CSC sales code: SPR Phone SN: R28JA0FQ4BY IMEI: 355982085762516 HW version: REV1.0 RF cal date: 2017.10.11 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2019-04-01 Boot Warranty bit: 0 SIM State: CARD_IO_ERROR Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Searching Samsung diag port... detected COM56 Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Checking data... error (4.0) Your phone has new security patch Done with Samsung Tool PRO v.37.0 |
09-02-2019, 14:15 | #2 (permalink) | |
Junior Member Join Date: Jan 2014
Member: 2098706 Status: Offline Thanks Meter: 3 | Quote:
09-03-2019, 23:38 | #5 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | for info Quote:
The Following User Says Thank You to ghacks For This Useful Post: |
10-28-2019, 18:45 | #6 (permalink) |
No Life Poster Join Date: Dec 2015
Member: 2494408 Status: Offline Thanks Meter: 110 | g950u (s8 sprint 9.0 ver) unlock help need new security It is carier Sprint , Only need flash combin firmware, then use z3x option G930P ,z3x unlock done, full flash stock firmware , 100% done , no need credit Sent from my iPhone using Tapatalk |
The Following 5 Users Say Thank You to thoiapple923 For This Useful Post: |
