01-09-2018, 16:10 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Between Heaven and Hell
Member: 563008 Status: Offline Thanks Meter: 108 | G950U unlock succesfull but no signal I use unlock by server and was done successfully but no signal on phone UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G950U Selected port: COM58 SAMSUNG Mobile USB Serial Port Software version: 30.4 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G950U Android version: 7.0 Product code: SM-G950UZSAATT Phone version: G950USQU1AQDE PDA version: G950USQU1AQDE CSC version: G950UOYN1AQDE CSC country code: USA CSC sales code: ATT HW version: REV1.0 Phone SN: R38J403DZ9X Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-04-01 RF cal date: 2017.04.04 IMEI: 35772308035 I will provide full imei on private if it necessary Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM18 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 19719314 NET lock: 02079407 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.4 here are some pics https://imgur.com/a/u1VaG https://imgur.com/a/FMXfv https://imgur.com/a/L80Nv please sugest what to do ! thanks in advance |
The Following User Says Thank You to pashamangl For This Useful Post: |
01-09-2018, 18:03 | #6 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Hardware prob baseband open the phone and heat baseband ic Sent from my Le X829 using Tapatalk |
The Following User Says Thank You to souma_k For This Useful Post: |
