G955N frp failed Hello, Could someone tell me how can i bypass G955N S8 plus korean model cauz i tried this method that failed... COMBINATION_FA70_G955NKSU1AQF1 then G955NKSU1AQG7 full 4 files ( home csc file chosen) but it doesn't allow me the access to get setting also i tried this key combination "BL" then select "AP" then skip "CP" then select "CSC" and hit write firmwarethen unmark this "Userdata,Metadata,pit" but even after done that it failed i get message: storage corrupted reset device.... is there any other method ? ( i tried also the bluetooth method but until calculator step *#0808# doesnt show dm adb mode) thank you |
No? does someone have any other method ? or maybe samsung has patched combination file method ? |
go to shop number 10 they have solution :p |
Bro you're right but while unchecking you are missing one thing First full flash the stock firmware then flash the combination file then while unchecking the stock firmware, uncheck all the others you mentioned and also uncheck "up_param" from BL, then skip CP and uncheck "pit" from CSC then hit flash. I gurantee you it will work!. |
hello i have G955N with frp version G955NKSU1AQL3 i try write combination file COMBINATION_FA70_G950NKSU1AQF1_CL11405575_QB138284 93_REV00_user_mid_noship.tar.md5 and get eror with z3x and odin. i think i need new version combination file if somebody help me please tnks |
here is the file with the same binary as yours, you looking for the new version of the combo, but bewared, once you go for binary 2, you can't go back to binary 1 https://androidfilehost.com/?fid=889964283620754650 this is the another one, ending with ae3 https://drive.google.com/a/valor-int...98_6cP4ZDCp2Dr hope it works. |
