01-11-2018, 18:44 | #1 (permalink) |
Freak Poster Join Date: Mar 2015 Location: CDA
Member: 2359179 Status: Offline Thanks Meter: 34 | G955u t-mobile cant unlock and lost credit UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G955U Selected port: COM20 SAMSUNG Mobile USB Serial Port Software version: 30.4 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G955U Android version: 7.0 Product code: SM-G955UZSATMB Phone version: G955USQU1AQHD PDA version: G955USQU1AQHD CSC version: G955UOYN1AQHD CSC country code: USA CSC sales code: TMB HW version: REV1.0 Phone SN: R28J41AE8CE Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-08-01 RF cal date: 2017.11.02 IMEI: XXXXXXXXXXXXXXXXX Rebooting phone... OK Waiting ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Rebooting phone... OK Waiting ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM7 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... Exception: Access violation at address 72C67358 in module 'RICHED20.DLL'. Read of address 00000008 Done with Samsung Tool PRO v.30.4 |
