04-10-2018, 22:04 | #9 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
04-10-2018, 22:35 | #10 (permalink) |
Crazy Poster Join Date: Jan 2013 Location: san diego ca
Member: 1863178 Status: Offline Thanks Meter: 15 | ok so i tried all this drivers plus others and none worked also tried other pc same result reading data from phone..... waited 5-10 mins nothing tried 2 new original from s9 box cables btw using latest drivers from samsung website 1.5.56 |
04-11-2018, 01:44 | #11 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
When then phone goes into ramdump mode and you see the message "waiting for diag/cp/ramdump mode", just un-plug and re-plug the phone to see if that helps. I have to do it every time I do an unlock. | |
04-11-2018, 19:29 | #12 (permalink) | |
Junior Member Join Date: Jun 2017 Location: paterson, NJ
Member: 2727207 Status: Offline Thanks Meter: 14 | Quote:
1- install the latest drivers from samsung 1.5.65.0 2- try another cable and computer 3- dial *#0808# and select RMNET + DM + MODEM 4- enable usb debugging from developer options. good luck | |
The Following User Says Thank You to swaqboy For This Useful Post: |
04-11-2018, 20:16 | #13 (permalink) | |
Selected model: SM-G965U Software version: 31.1 Checking Login and Password... OK Ballance: 25 crd. You have 25 credit(s) left. This operation takes 10 credits .Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G965U Android version: 8.0.0 PDA version: G965USQU1ARB7 CSC version: G965UOYN1ARB7 Phone version: G965USQU1ARB7 Product code: SM-G965UZKAATT CSC country code: USA CSC sales code: ATT Phone SN: R38K30APY9J IMEI: 353321091568777 HW version: REV1.1 RF cal date: 2018.03.10 Chip name: SDM845 Modem board: SDM845 Security patch: 2018-02-01 Boot Warranty bit: 0 Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM6 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 17246385 NET lock: 64696392 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# | |
04-13-2018, 07:35 | #14 (permalink) | |
Interestingly on some systems even if you have done those steps when the phone goes into ramdump mode, the device manager displays the modem port with a yellow triangle, but once you un-plug and re-plug the cable everything continues smoothly. It's a really weird issue but at least the workaround is a simple un-plug, re-plug... lol | |
