05-24-2015, 13:26 | #293 (permalink) |
Junior Member Join Date: May 2015
Member: 2398623 Status: Offline Sonork: Ububoh1 Thanks Meter: 0 | Greetings to you all,I really need your help please.i work under my boss who repairs phone hardware,someone brought an s6 sm-g9205t to the shop for repairs.i only took the phone switch it on and tried connecting to the Internet only to see the message saying phone has been locked by EE,I am being accused of trying to steal the phone and being asked to buy it for the owner. |
05-24-2015, 13:31 | #294 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: In My Pub
Member: 307549 Status: Offline Thanks Meter: 188 | Quote:
what did he ask you to do the phone. | |
05-24-2015, 17:08 | #295 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | G920TEEfixWIPE For the G920T. Use the directions from earlier in this thread (launch .bat file in custom recovery with proper ADB drivers, wipe data/cache, flash full firmware, wipe data/cache again, don't let phone boot into Anrdoid during any of this process).. This may or may not work. I took a different approach so that users won't need a clean phone to pull the files from. Instead, the partition is filled with zeros. |
The Following 8 Users Say Thank You to ecs87 For This Useful Post: |
05-24-2015, 17:57 | #296 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: UK. Worcester Age: 35
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | Quote:
Sent from my SM-G925F using Tapatalk | |
05-24-2015, 19:39 | #298 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | It should work with all G920 variants, but then again I've only seen the partition layout for the G920F and G920T. I wouldn't try it on a G925 variant until someone posts a legitimate partition layout to confirm the partition named are the same (at least for persist and persdata). |
The Following User Says Thank You to ecs87 For This Useful Post: |
05-24-2015, 20:13 | #299 (permalink) | |
Member: 2398623 Status: Offline Sonork: Ububoh1 Thanks Meter: 0 | Quote:
05-24-2015, 21:02 | #300 (permalink) | |
EDIT: Just checked the partition layout on mine g925f quickly using emulator and layout is identical to one bellow. C:\android-sdk\platform-tools>adb shell shell@zerolte:/ $ su su root@zerolte:/ # ls -al dev/block/platform/15570000.ufs/by-name ls -al dev/block/platform/15570000.ufs/by-name lrwxrwxrwx root root 2015-04-25 06:37 BOOT -> /dev/block/sda5 lrwxrwxrwx root root 2015-04-25 06:37 BOTA0 -> /dev/block/sda1 lrwxrwxrwx root root 2015-04-25 06:37 BOTA1 -> /dev/block/sda2 lrwxrwxrwx root root 2015-04-25 06:37 CACHE -> /dev/block/sda16 lrwxrwxrwx root root 2015-04-25 06:37 DNT -> /dev/block/sda10 lrwxrwxrwx root root 2015-04-25 06:37 EFS -> /dev/block/sda3 lrwxrwxrwx root root 2015-04-25 06:37 HIDDEN -> /dev/block/sda17 lrwxrwxrwx root root 2015-04-25 06:37 OTA -> /dev/block/sda7 lrwxrwxrwx root root 2015-04-25 06:37 PARAM -> /dev/block/sda4 lrwxrwxrwx root root 2015-04-25 06:37 PERSDATA -> /dev/block/sda13 lrwxrwxrwx root root 2015-04-25 06:37 PERSISTENT -> /dev/block/sda11 lrwxrwxrwx root root 2015-04-25 06:37 RADIO -> /dev/block/sda8 lrwxrwxrwx root root 2015-04-25 06:37 RECOVERY -> /dev/block/sda6 lrwxrwxrwx root root 2015-04-25 06:37 SBFS -> /dev/block/sda14 lrwxrwxrwx root root 2015-04-25 06:37 STEADY -> /dev/block/sda12 lrwxrwxrwx root root 2015-04-25 06:37 SYSTEM -> /dev/block/sda15 lrwxrwxrwx root root 2015-04-25 06:37 TOMBSTONES -> /dev/block/sda9 lrwxrwxrwx root root 2015-04-25 06:37 USERDATA -> /dev/block/sda18 root@zerolte:/ # Sent from my SM-G925F using Tapatalk Last edited by Thorenzz; 05-24-2015 at 21:28. Reason: Checked if correct. | |
The Following 4 Users Say Thank You to Thorenzz For This Useful Post: |
