05-25-2015, 00:22 | #301 (permalink) | |
Freak Poster Join Date: May 2011 Location: United Kingdom
Member: 1574069 Status: Offline Thanks Meter: 32 | Quote:
I can confirm thats correct, just made sure with another piece I had lying around. @ECS87 has provided with a file which should remove the EE message on the G925F. I will try and update as soon as possible Last edited by iMoG; 05-25-2015 at 00:27. | |
05-25-2015, 00:54 | #303 (permalink) |
Member: 1574069 Status: Offline Thanks Meter: 32 | Definietly possible, although I'm not sure how it works on HTC. You might need to unlock boot loader first. Anyways if you post your partition layout Im sure somebody will help you. Somewhere on this thread theres a guide on how to display the partition layout. |
05-25-2015, 02:14 | #304 (permalink) | |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Quote:
As stated in the post above mine, you will need to unlock your bootloader to load a custom recovery (unless you have a kernel level root that works) and root the device. You will then need to either post a layout of your partition map, or find a partition map from a HTC M9. | |
The Following User Says Thank You to ecs87 For This Useful Post: |
05-25-2015, 14:03 | #305 (permalink) |
Member: 1574069 Status: Offline Thanks Meter: 32 | So far the only issue I seem to be facing when using the Bat file is the android device appears as offline because the phone hasn't accepted the RSA keys and there is no way to in recovery mode. Has anyone managed to get passed that? The phone will be recognised by "adb devices" but appears in "offline" state. |
05-25-2015, 14:59 | #306 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | iMoG, you might be using a old version of ADB. The old version won't recognize the device as online. Try the adb files out of the newer Google Android SDK. |
05-25-2015, 18:07 | #307 (permalink) | |
Freak Poster Join Date: Aug 2012 Location: england
Member: 1798097 Status: Offline Thanks Meter: 86 | Quote:
just use them codes manually from .bat file | |
05-26-2015, 00:06 | #308 (permalink) | |
Anyways I will keep trying to see if I can find an alternate solution or to get yours working. Thanks for all the support so far EDIT: My ADB version is 1.0.32 Last edited by iMoG; 05-26-2015 at 00:13. | |
05-26-2015, 09:49 | #309 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: UK. Worcester Age: 35
Member: 1176876 Status: Offline Sonork: 100.1607051 Thanks Meter: 154 | Quote:
Sent from my SM-G925F using Tapatalk | |
05-26-2015, 11:51 | #310 (permalink) | |
just try this today Mr iMoG, i think you have not considered my reply much. well let me break it down for you, can not get simpler than this. 1. flash your phone with custom recovery TWRP. 2. go to Advance>file Manager "you will see adb port is detected." 3. i have uploaded the adb files. "you dont need the whole SDK updating." 4. open command prompt and go to the ADB folder i have uploaded. 5. write these following commands. adb.exe kill-server adb.exe start-server adb.exe shell dd if=/dev/zero of=/dev/block/sda13 dd if=/dev/zero of=/dev/block/sda11 6. after inputing these commands ,, do a factory reset. and you are happy to go. ofcourse all credits goes to "ecs87" | |
05-26-2015, 12:31 | #314 (permalink) | |
This time I only used the ADB files issued with the batch file. The phone is also working as usual, TWRP installed properly. The computer also detects it. So far I have tried 1) Changing USB port 2) Changing USB cable 3) Trying on another PC | |
